Sign-in / Sign-up
eVGA 7800GT Resolution Problem 1280 x 768
  • Graphics Cards
  • Computer
  • Resolution
  • Graphics
Last response: in Graphics Cards
March 21, 2006 9:55:15 PM
I have dual nVidia 7800GT's using the SLI technology. I am using a 26' Philips Widescreen monitor that has a native resolution of 1280 x 768. On my old computer that is the resolution that I used and liked. With this new computer and the new 7800GT's it will not display that correctly. The screen is all messed up, not distorted, it is just crazy looking when I try and use that setup. Is there anything that I can do to be able to use that resolution, because I'm using 1024 x768 right now and dont really care for it.
Any help is appreciated!
More about : evga 7800gt resolution problem 1280 768
March 22, 2006 7:38:42 PM
Anyone have any ideas?
March 22, 2006 7:40:42 PM
You have 26" monitor and its native resolution is only 1280x768? Must be a crappy TV monitor. Try turning off SLI when just running the desktop.
March 22, 2006 7:48:43 PM
I've tried turning off the SLI and it doesn't help anything. I've tried putting the DVI connector in each of the 4 ports on the video cards and nothing there as well.
March 22, 2006 8:09:28 PM
same monitor ? just different vid cards right? Did you try the latest video drivers? 84.21? try 1280x720 and see what the results are. I had a 27" that has native res of 1280 x 720 and a 30" that had native of 1280 x 768 they looked sweet even for being larger, also are you running DVI? or VGA-analog?
March 22, 2006 11:19:12 PM
Correct, it is the same monitor (Philips 26PF9966). With my old computer I had a ATI x800 Pro and it did the 1280 x 768 just fine. The monitor looks incredible at that res, but now it wont' display that correctly. When I click apply that res the screen is black with white lines all over it. My monitor wont support 1280 x 720. Also I'm using DVI not VGA connection.
March 22, 2006 11:21:15 PM
I dont really see how this could be a monitor problem due to it displaying it before plus that fact that 1280 x 768 is its native resolution. The video cards advertise that they will display that resolution too. I have the newest drivers that I just got today and still no luck.
March 23, 2006 12:53:20 AM
true , not doubting your monitor here. I am stumped , short of being a bad card , did you swap slots with the vid cards and try running single display off of the other card?
March 23, 2006 1:25:42 AM
I haven't tried that yet. I'll try that in the morning. Thanks for the tips. I'll let you know what happens
March 27, 2006 2:14:07 PM
I tried that with each card with no difference. I at a loss right now on what to try, short of just settling for the 1024 x 768.
