G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I just upgraded my XP Pro to SP2. Everything worked flawlessly.
It did go through and reset a lot of my customizations, especially
in IE.
Here is the problem.
My wife went to her school district web site to download this
year's calendar. It would not print across my network ( an issue
that has been fixed). At the time, I said "no problem", I'll just
print it from my computer.
I went to:
http://www.okcps.org/calendar/index.htm
her computer shows a clickable link under the text that says:
District Calendar, It also shows the clickable logo for Acrobat
under the text which says click on the link to acquire Adobe. . .
When I go to the same site I do not get either clickable link.
When I click properties at the link on her computer, it tells me
they are .gifs. I do not get the links, I do not get boxes with
the little red x. I reviewed the options in IE tools. I checked
the Knowledge Base. To date I have not found a reference to my
particular issue. I would not even know I had an issue were it
not for the flukey way we encountered it.
I have reset all options/security settings/etc to default. Still
no links, just empty line spaces.
Keep the whole world singing . . . .
DanG (remove the sevens)
dgriff237@7cox.net
in IE.
I went to:
dgriff237@7cox.net
