Problems with PPTP VPN and DLink DI-808HV
Forum General Networking : VPN, VoIP, Video Conferencing, Remote Connections - Problems with PPTP VPN and DLink DI-808HV
Archived from groups: comp.dcom.vpn (More info?)
Hi,
We have a Dlink DI-808HV router that implements its own VPN server
"in the box". I've set it up as a PPTP server with MPPE encryption
and, most of the time, it works fine.
Occasionally (i.e. once a day or so) when a Windows client attempts
to connect to the VPN server the negotiation will hang, during the part
where Windows says "Verifying user name and password" or "Registering
your computer on the network". Eventually Windows times out.
Sometimes retrying three or four times will fix the problem, and
sometimes it will persist.
This happens with different PC clients, running both XP home and
professional, and with different Internet paths (e.g. coffee shops,
hotels, GSM/GPRS cell modem, etc) back to the 808HV. Resetting the
router, if there's someone around to do it, always seems to cure the
condition for a while.
The same PC, with the same network path back home, will connect just
fine some times and fail others. Turning off encryption doesn't seem
to help. I've been in touch with DLink technical support and even the
second or third level support guys (the ones that sound like they know
what they're talking about) don't seem to have a solution. At least
they're honest about that :-)
Has anybody else seen this problem?
Thanks,
Bob Armstrong
Sponsored Links
hi,
i brazilian and not speek english very good, but i think, i need you.
in router : home - vpn - pptp server settings
creat de user than Authentication Protocol mschap
in the computer
creat vpn and go to proprets and security - advanced - configurations
enable only microsoft chap (ms-chap)
i solution my problen this form.
if solution your problen send, mail whit my (informatica@enplan.com.br)
thanks
Reply to ltfernandesssp
Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Problems with PPTP VPN and DLink DI-808HV
There are 495 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
