Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Monitor display question. Please help.
Forum Homebuilt Systems : General Homebuilt - Monitor display question. Please help.
OK, I am going to build a new computer soon, and am using a semi-old (2003?) monitor. I pressed the menu button on it and it said "800x600" in the upper left hand corner of the menu. Is this the maximum resolution of the monitor? Will I be unable to play games with a higher resolution then that? Please respond...I need help.
Sponsored Links
Most likely that is the current resolution you are running. Visit display properties in Windows and if the driver for your monitor is install the max resolution on the monitor will be the max the slider will go on the Advanced Tab. (Eg. if you monitor supports 1600x1200 thats the highest the slider will let you go for resolution)
Reply to shadowduck
That's the resolution your running at right now. Try messing around with the resolution by right-clicking on the desktop, and then clicking Properties. Once you've done that, a menu will pop up. Click the right-most tab and it should be Video or something like that. Just change the resolution and voila, it should change. Oh, and I think you should still be able to play games at higher-resolutions, like 1024x768.
Reply to steveosazninvazn
- 0 +
There's probably a model number on the back of the monitor, along w/ the manufacturer.
Google it. Find the specs.
Reply to nobly
There are 1107 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
