The answer is simple in theory. Add another level of cache, go for a big one and you’re home free. In fact, by creating a larger L3 cache, AMD will have the opportunity to reduce the size of L2 cache and save die space. 64+64 L1, 512KB or 1MB L2 and 2-4MB of L3 are the first things that comes to mind. The cache would of course, keep all two or four cores happy and keep the data flowing.
Pretty interesting. I found the 256-bit (Quad Channel) Memory Controller to be pretty nice, I figured AMD would go that route. I still can't see why people are comlaining about A64 RAM Latency, there is 4-3-3-8 DDR2-800, and that's damn near close to an Overclocked DDR1 module (minus the 4 CAS of course). What should be interesting is the L3 Cache, will it be Z-RAM or not?
wow meanwhile P4 xeons have much much more cache and no performance is gained
quad memory controller? intel doesnt even intrgrate it or have something like htt and it rips with conroe
what stops intel adding quad memory controllers and csi and htt? most is coming in ~3 years so when AMD "catches up" it will face another battle
another wasted topic as many stated before!!!!!
as the saying goes "anything you can do i can do better" - AMD vs Intel is always a leap frog and its true.
Meh. I don't see any performance gains going from DDR to DDR2. You just can't get DDR2 modules under CL3, even high-end Corsair and Crucial. It would take a hella fast RAM clock speed to gain back the speed lost by the higher CL.
...Off toppic...
@ActionMan
There should be sub_forum for keyboards, where you should be moderator, so you will have the right to delete post instead of telling people that they need a new kbd.
You can say something in context about the topic, for a change.
@apache_lives
You should be ignored for your post, but take this as friendly advice, if you don't have something to say about the topic than STFU and don't blame your self with stupid discussions that are not subject for discussion. Read the topic first, than try to understand what is it about and why the author opened it, than read the allready written posts about the subjects and try to be usefull with your own opinion if you have any.
AMD ATTACKS DDR-II LATENCY PROBLEMS
No Intel, Pentium, Intel beeing better than AMD or vice-versa are mentioned in the topic....
You know what, I agree with "another wasted topic as many stated before!!!!!", from the people like you.
I am just wondering when some people will understand that hardware forum is not for wasting time with pointless insulting out-of-context discussions. It is place where people should share their IT knowledge(learning and teaching) and will post intelegent discussions relative to the topics.
Back to the topic now,
Large L3 should improve memory bandwidth, but will not solve the problem. When more is needed and there is no L3 available, the CPU will suffer from the high latency again. If the future K8L have more cores with more processing units, it will need much more data than the dualcore K8 we have today. The need for L3 will go further and further, considering that AMD wants to implement DDR3(its higher latency memory than DDR2). It is unefficient on one hand, and on other is expencive.
Quad channel is not a solution also becouse it will give only theoretical bandwidth and the latencies will be the same. On the other hand it will complicate the building of a system using 4 modules of RAM and the systems will be more expencive(motherboard and more memory modules)
What they have to do is to implement a kind of memory scheduler that will put in sequentional order the memory operations and will reduce the number of memory accesses when they are not needed.
