Tom's Hardware > Forum > CPU & Components > Sound Cards > How to use the front audio case ports
Forum CPU & Components : Sound Cards - How to use the front audio case ports
I am looking for a soundcard in a $20-$30 range that would allow me to run cables to the front of the case for the MIC and SPKR plugs.
Does anyone here have a setup like this, and if so, how did you do it? What card and case did you use?
I am trying to build my own system. Any help would be very, helpful. :D
Sponsored Links
well I dont know for sure but, most sound cards will have it. But if you are looking for a 20$ card you should probably get a motherboard with onboard soun. Hooking up the front panel sound was difficult. but worth it. but what do you want to hook up to your sound card. headphones? stero speakers? 4 speakers 5.1? cuz I some 5.1 headphones and I decided I needed a new card. my on board wasnt good enough. So I'm getting the soundblaster x-fi xtreme music for lie 110$. but if you just want a cheapone your best bet is onboard sound. and hooking front panel up is usually confusing cuz they dont have very good directions. so you kinda gatta guess. for example. my directions showed mic in mic pwr my case had mic2 micbio (or somthing like that)
Reply to inuyashafly
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
