Closed
System Builder Marathon: High-Cost System
  • System Builder
Last response: in Reviews comments
Anonymous
April 15, 2008 5:48:47 PM
In addition to an Intel Core 2 Extreme QX9650 CPU, Asus Striker II Formula motherboard, and dual Gigabyte GeForce 8800GTX graphics cards, our high-cost system features a Swiftech H20-120 Compact cooler kit. So?
System Builder Marathon: High-Cost System : Read more
More about : system builder marathon high cost system
May 17, 2008 3:20:34 PM
Thanks for the great article - I'm having fun building this - I do have 3 questions though - the fan duct assembly fan has 3 wire sets, 1 has the 3wire motherboard connector, the second taps into a regular power lead. The third is a single wire - the case documentation does not describe that one - what is that little single lead for? Also the motherboard sound card has some connectors on it - I assume one is for the case headphone/mic lead? Third, should teflon tape be used in the dual radiator threads if not how tight is tight enough for the O-rings? Thanks great article!
Score
June 25, 2008 5:20:35 AM
Hi Thanks For The Great Article - I Am Also Building A System With A Few Modifications I Loved Asus Boards But Can Never Seem To Overclock Them At All So I Am Going With A EVGA 780i FTW when they come out, THat Processor IS Sweet But No Way CAn I JUstify PAying $1060 or more here in canada for 1 Pc Component when i already own three computers, I was thinking maybe a Q6850 when they come out, i have changed the middle fan in my case already and i am just waiting on my 120 rad to get here as i already have the other parts from another computer i built that i couldn't use so that saved me a few dollars:)  and i can't find that power supply anywhere so i am gonna do with a X3 1000 watt from ultra i hope it's good enough. and since i am not a really good overclocker no point in risking a high end system by messing around with 2 expensive graphics cards will 2 9800GTX+ work for me ? and omost importantly after my system is finished and filled how do i top it up if it needs more water do i have to take the top rad down to fill it everytime or can i just add water in to the same rad. thanks alot of your help and keep up the great work.
Score
September 6, 2008 5:04:43 AM
I've been installing and have three questions. First, there seems to be no pump in this system - have I just missed something?
Second, the twin fan radiator seems to draw the air from inside the case up through the radiator and then out the top of the case. Wouldn't you want to draw cooler air from the outside past the radiator?
Third, I don't see any connection to the video card although the 880GTX card is built for water cooling. Wouldn't you want to include this in the loop?
This is my first build with water cooling so sorry if the questions belie this.
Score
