Well, this will be my first real build, but I have taken apart my current computer a few times and swapped some stuff out. My goal for this PC is to be a decent gaming machine for under $700, but I could go as high as $800 if there was a good reason to. I've searched around online and here is the list of parts I think I want.
CPU: AMD Athlon 64 3200+ Venice 1Ghz HT 512 KB L2 Cache Socket 939 (will be coming with a Thermaltake AMD K8 7+ heatsink fan)
MOBO: Asus A8N5X nForce4 (no firewire port, if there is a comparable mobo w/ a firewire port I'd be happy to get that one)
RAM: CORSAIR ValueSelect 1GB (2 x 512MB) 184 Pin DDR SDRAM. I have another 512 MB (2 x 126 MB) that may or may not fit (I forget what pin type they are). If it doesn't I will add more RAM when I get the money.
HD: Already have a 40 and 100
Video Card: eVGA GeForce 7600 GT CO 256MB 128-bit GDDR3
Sound Card: Already have a current one
PSU: ASPIRE ATX-CW500WP4 ATX 500W Power Supply 115/230 V
DVD/CD drive: Plextor, reads CD's @ 48x and DVD's @ 16x
CASE: COOLER MASTER Centurion 5 CAC-T05-WW
Well, time for questions
1. A friend told me that basically any sound card will fit into any mobo without any problems, is this true?
2. The PSU has a potential fo 500W of power. I'm guessing this should be enough, but I'm not sure.
3. The case I plan on getting has a 80mm fan and a 120 mm fan. Will both of these be able to keep the machine cool.
4. What do you think about the Asus mobo, if you have a better one in mind I'd be happy to switch.
5. I think that all of the parts will mesh together nice, but I'm not 100% sure.
