What is the best aftermarket GPU cooling (not H2O cooling)?
I need to know what is the best air cooling anyone knows about or has used and how well it cooled the video card, especially if the videocard was heavily overclocked. I am also looking for the best possible performance modifications without changing the physical card itself (ie. bios flash, pipe unlocks, etc.). Thanks.
1 answer Last reply
More about what aftermarket cooling cooling
  1. Well in that case you might wanna look at Zalman and Artic Cooling GPU coolers then. But it depends on what video card do you have. Care to tell what it is?
GPUs Cooling Internet Explorer Components
