is there anything decent for memory water cooling?? I know this one: http://www.directron.com/bkaframcooler.html but that wont work well if you have 2 sided ram (cant remember the term for it) and more than 1 stick.. anything out there??
water cooling your ram its not really worth it as a normal heatspreader its good enough in some cases, unless ur gettin this for show...
Check out the option from Koolance
http://www.koolance.com/shop/product_info.php?products_id=251
Definetly looks cool.
