All this talk about heat ... from reading the Video card forums and the gamers forums complaining about heat, has made me concerned about adding my newly acquired ATI X800XT PE without doing something about cooling.
I'm thinking about using some scrap heap PC's that I never got around to throwing away, by taking one of the Power Supplies and putting it in a plastic housing so I can use the 12volts to drive two 120mm fans that I will add to the case of my PC by removing the side panels and cutting a hole.
I figure, 1 fan exhausting air and the other blowing air should get the PC ventilated. All this for the inexpensive price of 2 fans and no additonal drain on my PC's power supply.
Whadda think? Should I do it?
Sony Vaio PCV RZ46G (Mobo OEM Asus P4SD-VX) 3.2ghz 1G Mem 400GB HDD - PIONEER DVR-106D; NEC ND-3520A - ATI Radeon 9600XT w/256MB Driver 8.221.0.0, XP Media Center Edition 2005 SP2 Creative Audigy
