Tom's Hardware > Forum > Computer Peripherals > Printers > Imageprint installation problems
Forum Computer Peripherals : Printers - Imageprint installation problems
Archived from groups: comp.periphs.printers (More info?)
Thanks. You were right. I just had to convert back to RGB and then it
opens fine in Imageprint. No more multiplying-problems.
But...now I wanted to print under Imageprint and it just doesn't do it.
I have followed the Imageprint installation instructions for the setup
and did everything correct. I have windows 2000, USB connection. At the
set up I gave instead of USB001 the name 'EPSON Stylus Photo 2200' as a
port. That was according to the instructions.
Under control panel after the installation of Imageprint there are now
two printers installed. One is still the old original EPSON Stylus
Photo 2200 and the other is called just Epson2200. I tried using each
of them as a default printer but neither seems to print under
Imageprint. I played around with port settings (first I tried USB001
and then C:\Program Files\ImagePrint\spool\printers\Epson2200) under
Ports, I set it on 'print directly to printer', driver is 'Imageprint'
with the Epson2200 printer under advanced.
Worth mentioning is that at windows start up an error message comes up
telling that a printer driver failed to install. This window never came
up before the installation of Imageprint. And with the Epson2200 I am
not able to print a test page, so already at this point it fails. The
printing icon appears in the task bar and goes away, but no test page.
Man, what am I doing wrong? Thanks.
Sponsored Links
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
