G
Guest
Guest
Archived from groups: alt.games.microsoft.flight-sim (More info?)
Lately, most of my add-on aircraft seem to have developed a control problem.
I first I thought it was a problem with the auto-pilot. I use the auto-pilot
feature for long flights. What would happen is about halfway through the
flight, the aircraft would attempt to go vertical. I would have to turn the
auto pilot off and keep the joystick all the way forward just to maintain
level flight. This problem happened when flying a gulfstream aircraft.
I did another short flight today using a C-130. I used the auto-pilot for
the duration of the flight and there were no control problems. I was coming
in for approach, and the runway lights indicated I was on the correct glide
slope (4 white lights). I then realized that I was getting the four white
lights in error because I was too high to land so I had to go around. I
intially couldn't get the plane off the ground. Once I did, the plane lost
all control and I had a very hard time flying it manually. The instant I let
go of the joystick the plane would go vertical. This was happening without
the auto pilot on. I had increased the throttle to full and the flaps were
retracted so it is definately not an issue of going to slow. I don't know
that I can adjust the trim and still be able to fly the heading and keep a
level altitude. I'm wondering if completely removing FS and reinstalling it
will fix these issues? I have recently installed the FS 9.1 update, but this
was an issue prior to the update. This particular issue limits the aircraft
that I can use.
that I can use.
