Hello there,
I've been encountering certain problems with my computer for quite a while now, I believe the problem originates from the motherboard but I'd like to hear what you guys think.
I'm using an old Aopen AK75 motherboard with an (underclocked) AMD AthlonXP 2400+
The first peculiarity I encountered was when I first upgraded from a 1ghz tbird to the athlonXP, I tried setting the FSB to 133mhz so that I could get the correct frequency, but the computer wouldnt POST properly. I switched back to 100mhz fsb and let the thing run underclocked at 1.5ghz.
After a while some odd things began to happen, specifically when I ran anything that was processor intensive, or perhaps used up a lot of ram (even though I have ~1.3GBs of ram)- my computer would promptly power down. I thought perhaps this had to do with either the power supply or the actual electricity that was being supplied through the socket.
I tried isolating the problems, I switched rooms and I switched powersupplies, I removed one ram module after another, I ran memtest, an so on- the same problem persisted.
Now however, my computer doesn't power down, it freezes. For example I run a game which requires a good sum of resources, and halfway through I hear a click and then I believe the hard drive powers down and starts back up-- after about 15 seconds the computer freezes and the mouse doesn't move.
I replaced the hard drive and I still heard a click before the computer froze, but my original hard drive is the unit that sort of powers down and powers back up after the clicking noise-- I might try replacing the hard drive with yet another one and see if that solves the problem but I'm pretty sure the motherboard has a problem.
I'm not sure what I should do, so any help would be appreciated. If you want any more information that I can provide, please let me know.
Thanks in advance!
Thanks in advance!
