Sipura low ring voltage problem ...
Forum General Networking : VPN, VoIP, Video Conferencing, Remote Connections - Sipura low ring voltage problem ...
Archived from groups: comp.dcom.voice-over-ip (More info?)
I am having trouble with my Sipura SPA-2000 (through BroadVoice). I am
fairly sure that the problem is related to low ring voltage.
I have had several problems related to caller ID. I cannot get caller ID to
show up on my InTeleScreener device and I have trouble with call-waiting
caller ID on some older Uniden 900Mhz phones (DXI 386-2).
I am unable to experiment with the Sipura because the regional settings are
locked by BroadVoice.
Today, I bought a voltage meter so that I could check actual ring voltage. I
still have my SBC POTS line as well as the BroadVoice sipura to compare.
Sure enough, the SBC POTS line consistently provided an AC ring voltage of
84-85 volts.
Running the same test, the Sipura only provided a maximum ring voltage of
44-45 volts even though the configuration says that it should be set to 70
volts with a range of 60-90 volts.
I was very careful with my measurements and used a .1 microfarad capacitor
to filter out DC when measuring AC ring voltage.
Based on these findings, I have to assume that the Sipura is probably
defective, or that it needs a firmware update.
Has anybody else run into a similar problem? Is the unit defective and
should I ask for a replacement, or is this common across all Sipuras?
Other than this issue, the Sipura has worked extremely well. I currently
have BroadVoice as well as FWD on line 2 running.
Sponsored Links
Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Sipura low ring voltage problem ...
There are 1185 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
