Archived from groups: comp.periphs.printers (More info?)
Hi to all,
I bought two print servers Dlink DP-300U (2parallel ports + 1 USP).
I connected them in a small office network with TCP/IP protocol.
They work correctly with HP plotter and InkJet printers but I have problems
with a Laser Printer EPSON EPL 5700L present in Dlink compatibility List
(compatible only through parallel port). At the end of the printing a
"connection error" message appear on PC and all the LEDs of the print-server
begin to flash requiring a reset of the print-server (power switch OFF-ON).
The printer works without problem when connected to a PC and shared.
