Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > loking for decent power supply replacement
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - loking for decent power supply replacement
i'm looking for a power supply to replace the one that came with my atx mid tower case.i'm getting pretty confused with all the reviews and recommendations from different web sites.i'm a casual gamer and overclock my system a bit but nothing to crazy.thanks.
Asus P5LD2 motherboard
P4 3.0 GHZ processor
1gig ram
EVGA 6800GS 256 mb PCI xpress graphics card
Evercase midtower case with 350 watt power supply with a couple of fans
Sponsored Links
This
is a pretty good PSU and it will be more than enough for your set up. If you whant a realy good PSU that you will be able to use in future builds you can with this
Reply to jumpmaster
- 0 +
Jump threw out a couple of nice PSUs - especially the Blue Storm. In the middle of those two is another great option: Fortron 450W for $50.
Reply to Rugger
There are 542 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
