2 atx power connections, which to use?
hi all , i have a abit aw8-max mb and putting a northq psu in , the mb has 2 power connections , a 24 pin connection ( atxpwr1) and a 4 pin connection (atx12v1). mb came with a adapter for 20pin power>24 pin
psu has a 4pin power cable that fits atx12v1 , and a 20pin cable that connevts to atxpwr1 whan use that adapter
which should i be using? or both ?
both sounds scary if wrong lol
1 answer Last reply
More about power connections
  1. You will need to use both connectors or your board will not POST or if it does...won't be stable.
Power Supplies Connection Power Components
