Tom's Hardware > Forum > Graphic & Displays > Nvidia > Looking for: GeForce 7600 GT with 300 Watt power supply
Forum Graphic & Displays : Nvidia - Looking for: GeForce 7600 GT with 300 Watt power supply
Hi,
I got 3 questions...
I would like to know if there is a geforce 7600 gt that only required a 300 Watt power supply instead of 350 or 400?
Which ATI video card is comparable to the 7600 gt and only requires a 300 Watt power supply?
What 350+ power supply should I buy for an eMachines T6528 desktop?
Sponsored Links
Quote :
Hi,
1. All 7600GT requiers the same amount of power.
2. It is not 300W or 350W that is important. What's important is how much ampere the PSU can deliver on the +12V-rail. A good 300W is better than a bad 500W.
3. There is a lot of choices.
Reply to the_guru
Quote :
Thanks for your reply!
Basically I know nothing about power supplies and I just don't want to mess up the other devices...the T6528 has an Athlon 3400+ (entire overview can be found here ) so what would I want to buy in order to have the other devices work probably and also have a 7600 gt work ?
Thanks so much :)
Reply to Whattobuy
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
