Hi Im thinking about buying one of the following LCD Monitors, Im getting it pretty cheap. Can anyone please give me some advice. Have have aslo posted in the hardware general section.
BenQ FP202W :
LCD Size 20"
Resolution (max.) 1680x1050
Pixel pitch 0,258 mm
Colours 16.7 million
Horizontal Frequency (Max) KHz 81
Vertical Frequency (Max)Hz 76
Video Bandwidth (MHz) 25 - 182
Viewing angle (L/R;U/D) (CR>=10) 170/170
Display Area 433.4 x 270.9 (mm)
Contrast 600:1
Brightness 300 cd/m2
Response time (tr/tf) 8 (5+3) ms
Colour temperature Reddish/sRGB/Bluish + user mode
Input connector D-Sub/DVI-D
Power supply Built-in
Speaker No
USB No
VESA Wall Mounting Yes (100 x 100mm)
Swivel No
Pivot No
i-Key Yes
Kensington Lock Yes
Product Colour Black
Benq FP93GX
LCD Size 19"
Resolution (max.) 1280x1024 (SXGA)
Pixel pitch 0,294 mm
Colours 16.2 million
Horizontal Frequency (Max) KHz 31 - 81 KHz
Vertical Frequency (Max)Hz 60 - 76 Hz
Video Bandwidth (MHz) 25 - 135 Hz
Viewing angle (L/R;U/D) (CR>=10) 140 / 135
Display Area 376.3x301.1 mm
Contrast 700:1
Response time (tr/tf) 2ms Gray To Gray
MTBF (hr, exclude lamp) 60.000
Lamp life(hr) 30.000
Input connector DVI/D-Sub
Power Consumption 40W
Power Saving Mode 1W/120W
2W/240V
Net Weight 5 kg
Gross Weight 6.5 kg
Dimensions (HXWXD) 410x404.2x168.2 mm
Speaker No
USB No
Swivel No
Pivot No
OSD Control 8
i-Key Yes
Kensington Lock Yes
Product Colour Silver-Black
Thanks
BenQ FP202W :
LCD Size 20"
Contrast 600:1
Speaker No
USB No
Swivel No
Pivot No
i-Key Yes
Kensington Lock Yes
Benq FP93GX
LCD Size 19"
Contrast 700:1
2W/240V
Net Weight 5 kg
Gross Weight 6.5 kg
Speaker No
USB No
Swivel No
Pivot No
OSD Control 8
i-Key Yes
Kensington Lock Yes
Thanks
