Tom's Hardware > Forum > Graphic & Displays > ATI > 2x 6600 or 6800 ultra? help
Forum Graphic & Displays : ATI - 2x 6600 or 6800 ultra? help
getting ready to buy a comp, need help. which should i get or what should i get thats better for the money.
this comp is also going to have a dual core processor in it if that helps.
Sponsored Links
Hi
have a look at www.xfxforce.com that will give you information on the 6600 and the 6800, I have the 512mb pci expressx16 nividia 6600 and its ok for the games I play, but the 6800 looks even better with faster clock speeds.
Reply to Tron014
Quote :
Neither. Join the future and get nothing less than a 7600GT/X1800GTO. If you're looking to overclock, I'd recommend the ATI; it'll overclock to near-XT speeds and unlock to 16 pipes with a little luck. All of that for $200. And if you get a Crossfire motherboard, you can buy another one when you have the $$$
Reply to angry_ducky
You should get a "Pee" Four
There are 1174 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
