I have a regular ATX (no pci express or sata
connections) system that is louder than anything in the
house.
Which power supply (please not TOO expensive guys and gals!)
would work? I need at least a 350w and not to exceed 450 -
it's not a power system but I do need some quality. Silence is
golden - and I need some!
Additionally, I have a mini-atx case - $119 is a bit much
for a quiet p/s... any and all ideas will be MOST appreciated!
Which power supply (please not TOO expensive guys and gals!) would work? I need at least a 350w and not to exceed 450 - it's not a power system but I do need some quality. Silence is golden - and I need some! Additionally, I have a mini-atx case - $119 is a bit much for a quiet p/s... any and all ideas will be MOST appreciated!
I am not sure, but it looks like the same as my FSP 450W which I have in a CM Centurion 5 and together it is only a whisper. The only fan that is audible in the system is the BFG 6800GT, which is painful to listen to now...
Wow... 0dB is GOOD... but wow on the price too! (ouch...)
The "fan" based p/s - any dB ratings?
Thanks! You guys rock! (generic guys meant... if any of you
are girls... you're included... I am female - not easy being
female and a computer tech... really.)
Sparkle Power International (SPI) was recommended by a poster child (j/k) and is a brand name of the FSP Group. The FSP group also sells under the brand "Fortron Source".
Micro ATX is a motherboard form factor. Micro ATX cases are...cases designed to hold, at most, a Micro ATX board.
There is no such thing as a "Micro ATX" or "Mini ATX" power supply. The smaller standards have their own names.
SFX is the name for the most common small ATX power supply standard. These were made popular by eMachines...but nearly everyone else has them now.
PS/2 is the size everyone calls "ATX" when refering to a full sized supply. PS/2 is actually a size for both ATX and earlier AT power supplies.
PS/3 looks like PS/2 from the back of the case, but it's shorter in depth, for shorter depth cases. Many cases that use PS/3 power supplies are "able" to use PS/2 so long as the CD-ROM drive isn't too long.
Hardly anybody knows this stuff, I'm here to educate
Because hardly anyone knows about power supply size standards, sites like Newegg will typically group several small power supply standards under the "Micro ATX" heading and hope you magically pick the correct one.
I am a computer technician (17 years worth) who was out of the "game" for over a year and in that time a LOT has happened. I've had to do the "catch-up" thing for the second time... last time was before 1995... that wasn't much fun either. Both times I am finding that the terms or just the acronyms for termns that I know have changed yet again.
I have to get this computer quieted down... it's driving me batty.
My next task is to set up a wireless network for a friend... without much working knowledge. I'd set up quite a few two plus years ago, but they have changed QUITE a bit since then and the stability of most wifi networks "back in the day" was awful.
Any pointers to GOOD places to discuss wifi and all the different iterations (including pre-n and others that might fit the bill with some legacy and non-legacy hardware) would be most appreciated.
Unless you can get a pre-n unit for an incredible price, I'd hold off and just get the cheapest decent quality setup you can find. I am using a G w/ speedbooster only because I got it so cheap. Once the n units are available, wait for prices to drop, then maybe a sale+rebate. That may takes months after the release, maybe over a year.
if ur gonna do wireless internet Linksys is the best way to go they work with most ISP's and are good pieces of equipment, i got a wired router from them runs 24/7/365 no probs it should work with the dell too (wireless) linksys is pricey tho, also links ys makes set up VERY easy, just gonna read the manual thingy and set up the router using ur PC by typing 192.168.1.1 and it will allow u into the routers console, u can forward ports etc, very easy
as far as PSU's the PSU i suggested is good for ur needs, Thermaltake is a godo company not top of the line, but good, if u dont like thermaltake go for the Antec NeoHE seies or Truepower series
