Hi, I'm posting this because I just don't know what to do next with my TV capture card.
It's a cheap-o card, but has a Philips 713x chipset, which I thought would make it okay. However, when I use WinDVR in conjunction with either the S-Video or Composite inputs, I get a 'stuttery', low quality picture. Whichever one I choose the problem is the same.
I'm looking to record some old video tapes to my PC for editing and DVD'ing, but at the moment there's no way I can.
BTW, I got an external digital TV tuner to work fine through the card, so surely there can't be any problem with it (??).
I'm capturing MPEG-1 352x288 CBR. It's just about the lowest setting you can get. It's running on a Sempron 2200+ with 640mb of DDR333 and a Radeon 9200 64mb graphics card. Surely even that spec can encode realtime MPEG-1??
