Im experienced im going to run this through quick
WINDOWS 7
Theres problem with being able to go to google and such it redirects and thats because of the hosts file
I cant modify the hosts file because it says access denied
I cant see the hosts file in the explorer directory even though I am the ADMIN and have SHOW hidden files ON
The read only seems to be stuck although its hard to right click a file to remove it if you can't see it, solutions tried to fix it
Becoming parents and security advanced giving myself ownership of the Directory (still cant see file and no luck changing it)
going to admin run as CMD.exe to directory attrib -r -h hosts no go either
Trying running NOTEPAD as admin and going to file to attempt to change cant do
I did have SPYBOT and SUPER ANTI SPYWARE on, and I found out they lock the hosts file, I tried to remove the ticks and check marks but they wouldnt stick.
So I uninstalled both programs and they are no longer on the machine
There is no other virus or protection software
The firewall is disabled.
And finally I need to do this remotely for someone, so I dont have the ability to do a safe mode , console or anything, there must be a way. What am I missing guys
WINDOWS 7
