First off, I'd like to blame the crappiest chipset ever - the Via K8T800 Pro - and some crappy BIOS support from Asus (the newest BIOS is from 12/05).
Anyway, I fiddled around with some overclocking stuff in the BIOS, OC'ed the processor 3% for giggles, and turned it back down cause it was totally worthless. Then I realized I needed a BIOS update and downloaded 1017 (latest stable) from Asus' site. Restarted, first off it told me bad checksum in BIOS, then when it got back into Windows reported my proc speed as 1.4GHz-ish (CPU-Z), having changed the multiplier down to 7 until I restarted again, and when I started back up and tried to play some games:
a.) Counter-Strike Source now freezes between 10-30 seconds, about 2 minutes after I join a server and
b.) GTA-SA locks up completely every eight minutes or so but recovers in about 20 seconds, only to repeat ad infinitum.
I've had my video card OC'ed to 423 MHz Core/1.15 GHz Memory pretty much since I've had it and 70c was pretty much as high as it ever got, after 3DMark05 or F.E.A.R., but now even playing GTA or CSS immediately sends the temp up to 85c and idles around 60c, when it should be about 45c idle.
It also reports the ambient case temp as 58-62c when this is not true, the proc itself (AMD64 3400+ Newcastle) runs about 34c, 38c under load (gaming, not stress testing).
The cooling has not changed, nor have any clock speeds; everything is the same it has been for over a year now, the only changes are software (firmware?), latest NVidia driver and new BIOS, and the problems didn't appear until I changed the latter.
I would just blame it on the bad BIOS or incorrect temp readings, but I've changed it to a newer beta version BIOS and still have the same problem, not to mention the fact that the card seems to be throttling (and what wouldn't at 85c?)
Thanks in advance for any help.
