arctic cooling freezer 64 pro
me1234
44
what do u guys think of this cooler. id like to buy it for my x2 3800+ and overclock it a little. ive seen some reviews and it looks very interesting, also the price is great. can i take it to 2400mhz? i have a k8n sli platinum, 7800gt, corsair 2x512mb xms c2pt 2.5-3-3-6 currently at ddr440
WOWchamp
228
THIS is better then the zalman 9500?????????
ARCTIC COOLING Freezer 64 Pro Cooling Fan with Heatsink
Thats weird.... a person I talk to alot says it dropped him about 5-6C on average with an already OC'ed processor (an X2 3800+ @ 2.5ghz). I thought the 9500 would drop you like 10C in that situation.
uber_g
1,671
heh
i just bought one a couple of hours ago
-shipping from newegg.com
:D
i read some reviews -google
and the reviewers said to use the Thermal pad that comes with the Heatsink ,its some special compound they put on for optimal performance
shawnlizzle =]
1,061
i would have to disagree wusy, i really dont' like how madshrimps tests their hsfs.
in my opinion, for a somewhat consistent result, you at least need a stable heatsource (no CPUs and crappy burn programs). and a industrial temperature monitor and probe (absolutely no shitty mobo sensors)
they also do not provide you with ambient temperatures and case fan setups. they have way too many major variables to narrow down the temperature differences to the HSF
GherkinPekul
370
The stock thermal material over arctic silver?
Has anybody done a comparison?
I'm just curious because I'm planning to buy this hsf for my new build.
$6 I can save on Arctic silver is $6 more for my videocard budget.
uber_g
1,671
yeah on my Freezer pro they just dont use any thermal pad
they put there special MX-1 thermal compound wich is like A5
they work about the same way
the company said it was optimized for my heatsink
but A5 is a good product =]
here it is -Pc
the Freezer 64 has very good cooling
AMD 64 3200+ @ 2.4ghz
1gb twinx1024
6800gs @ 490-1100
shawnlizzle =]
1,061
the thing with motherboard sensors is that the temperature is not an actual reading, but an calculation. mistakes can be made both ways and are usually random on motherboard sensors. temperature differences usually range from 1-5c optimistically.
5c is a huge difference comparing top notch hardware where the difference can come down to 0.5c. (take the storm G5 for example).
what i'm trying to say is that even if they are using the same mobo for all the hsfs tests, it can still make random mistakes that will throw off the data
shawnlizzle =]
1,061
the review again uses motherboard sensors and asus is notorious for making shitty temp readings. also, you have to allow an amount of heat cycles on the as5 for it to perform at standard. so as5 actually performs better as time goes on
at best you proven to me that the mx1 compound is decent and should be considered as an alternative
uber_g
1,671
do u read all the stuff they did , i mean cmon dood
they dont use the motherboard sensor
but mehhhhhhh y spend 6 bucks for something thats good enough
shawnlizzle =]
1,061
oh my bad... i didn't see the probe, that adds a lot of legitamacy to the review
then i guess mx1 isn't a bad heatsink compound at all, but just to be anal i would've liked to see that probe be attached to the core itself, not the ihs. there is actually a recognizable temperature difference between teh core and teh side of the ihs
phillyman36
106
did u buy the plain model or the pro? and what is your cpu [just to get an ideea]
I got the Artic cooling 64 pro my rig is
Amd x2-3800
Asus A8N5X mobo
My case is a Chenbro gaming bomb 2 the exhaust of the fan on the cpu lines up with the exhaust fan on my case perfectly. i overclocked it once to 2.2 and temp stayed under 40c.
GherkinPekul
370
Thanks for the links Uber G.
Truly, this will save me $12, as I was going to spring for the hsf cleaner also.
That's about enough to spring for a 512 mb x1800xt instead of the 256.
I hope the Easter Bunny brings you something nice (if that's what you're into).
uber_g
1,671
no prob
i read alot of reviews before i buy a product
if u need something looked up'd i will happly help anyone with some product advise
or ask other people
jesus loves !!
