New PC will buy parts in next couple of days, did I forget anything or any suggestions on other parts. It will be used for light gaming and internet etc. Any compatibility issues?
Update Antec LifeStyle SONATA II Piano Black Steel ATX Mid Tower Computer Case 450Watt SmartPower 2.0 ATX 12V V2.0 for AMD & Intel systems Power Supply - Retail
Model #: SONATA II
Item #: N82E16811129155
In Stock
$99.99 -$8.00 Instant $91.99
Update ASUS A8N-E Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail
Model #: A8N-E
Item #: N82E16813131530
** This item is warranted through the product manufacturer only.
In Stock
$92.99 $92.99
Update eVGA 256-P2-N553-AX Geforce 7600GT 256MB GDDR3 PCI Express x16 Video Card - Retail
Model #: 256-P2-N553-AX
Item #: N82E16814130283
In Stock
Mail-in Rebate
$179.00 $179.00
Update AMD Athlon 64 3700+ San Diego 1GHz HT Socket 939 Processor Model ADA3700BNBOX - Retail
Model #: ADA3700BNBOX
Item #: N82E16819103539
In Stock
$219.00 $219.00
Update CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TWINX1024-3200C2PT - Retail
Model #: TWINX1024-3200C2PT
Item #: N82E16820145450
In Stock
$94.00 $94.00
Update Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #: WD2500KS
Item #: N82E16822144701
** This item may only be returned for a replacement of the same make/model within 30 days only.
In Stock
$93.00 $93.00
Update LITE-ON Combo Drive Black IDE Model SOHC-5236V BK RTL - Retail
Model #: SOHC-5236V BK RTL
Item #: N82E16827106992
In Stock
$26.99 $26.99
Update Arctic Silver 5 Thermal Compound - OEM
Model #: ARCTIC SILVER 5
Item #: N82E16835100007
In Stock
$5.99 $5.99
Actually, if you're going to crank out more cash on the system, go for a better videocard. A 3700+ will surf the internet just fine (A P3 will surf the internet just fine) and it beats out the X2 3800+ in -EVERY- CPU chart that is related to gaming. And it costs less. Alot less.
If the system is primarily for gaming, you made great picks. If you're going to splurge somewhere, move up to a 7900gt for about another $150. It's an amazing card for the money, and will make the LARGEST difference in framerate for the money. You might consider going to 2GB memory, if you feel like splurging a little bit. Even then, you probably won't notice a large difference, but you will notice one.
I do get really tired of people trying to tell gamers to get a dual core processor that performs WORSE for most current gen. gaming and costs alot more. Want better gaming? It's all about the videocard.
Thanks for everybody's replys. I would love to get a better video card but can't fit in my budget. I am planning to ad a another 1GB soon, just can't do it right now. I agree with simplyput about the dual core processer. In my opinion, right now the dual cores are not that great for gaming and in most cases are overkill for most users.
Agreed that dual core is not the fastest with games right now.
Ram suggestion is get 1Gb stick now and add the second later if it wont be that long. The dual channel performance hit should be around 3-4%. But you wont have the 2T penalty when you add the second gig unlike if you went with 4 sticks of 512mb.
