I had recently bought this product but came have some problems during the install. I have plenty of room for it so thats not an issue. I have an Asus32 Deluxe so I'll be using the K8 alternative method.
Okay, when putting the back H clip are you suppose to use the sponge or anything like that? doens't show it in the directions. So i didn't. But should the metal h clip be touching the mobo directly? I had some small washer on the back of my board from pervious heat sink so i decided to leave them on. Put the h clip on the back put the washers on the top ran the standoffs onto the screws to secure the screws.
Appllied some Artic 5 thermal compund on the cpu. Next i put the big typhoon onto the cpu and tighten the nuts to secure the typhoon in place. Believe i did all that correctly.
Turned on my computer and immediatly got cpu overheat warning. In fact was extremely high 125 C immediatly turned it off.
I then took the typhoon off saw on the heat sink and cpu there was good contact and enough thermal compound. I then just switched back to my old heat sink and fan and everything is normal again.
So if anyone has installed this product I'd greatly appreciate some help and knowing what went wrong.
