PSU, Motherboard, and 12v Connection Question. . .Help
Last response: in Systems
Related ressources:
- ForumQuestion about 4 pin 12V ATX Adapter
- ForumSingle 12V rail or multiple 12V rails? The eternal question answered
- ForumFaulty psu ?, combined amps on 12v rails?, and future proofing my rig?
- Forum500w psu with 2 18a 12v rails enough for GTX 260?
- ForumHard Disks Failing, PSU + 12V rail reported at 1.7V!?Event Errors Occur
- ForumCould this system run on a *500W PSU * [375W, 31 Amps 12V , Dual rail]
- ForumBest (FAST) PCI-E Card for a 18 amp on 12v line PSU
- ForumHD 4650 with 250W PSU (14A 12V ) with Quad Core prossessor?
- ForumThermaltake Toughpower 700W ATX 12V 2.2 SLI question
- ForumAtx12v eps 12v ???
- Forumquestion on the + 12v
- ForumPSU w/ 18A on 12V rail for GTX 650?
- ForumMB power supply using ATX 12V plug?
- ForumComputer not powering on when 4 pin connector 12v cable is out
- ForumPCI compatibility question
- ForumDESPERATELY NEED HELP . . .Reboot Problems
- ForumUpdating BIOS Question
- ForumCan you help with booting problems/new system?
- ForumSLI or Not to SLI, that is the question.
- ForumHelp me out: MB and power supply needed
- More resources
