Well this will be the first time I've put a complete system together. I have a limited budget, so I'm near what I intend to spend. What I will be using my system for:
Serving files via IRC, Some Video work- ripping dvd's and the like, some photoshop, lots of raring/unraring
I won't be playing games much, and I won't overclock. Here's what I'm intending to buy:
ASPIRE X-Navigator ATXA9N/500 Beige Steel ATX Mid Tower Computer Case ATX 500W dual fan power supply w/ automatic fan speed control Power Supply - Retail
Model #: ATXA9N/500
Item #: N82E16811144165
$84.99
Thermaltake 18" Black IDE(ATA66/100/133) Round Cable Model A2049 - Retail
Model #: A2049
Item #: N82E16812183033
$4.39
ASRock 939SLI32-eSATA2 Socket 939 ULi M1697 ATX AMD Motherboard - Retail
Model #: 939SLI32-eSATA2
Item #: N82E16813157087
$82.99
ASUS EAX550GE/TD/256M Radeon X550 256MB DDR PCI Express x16 Video Card - Retail
Model #: EAX550GE/TD/256M
Item #: N82E16814121544
$65.99
AMD Athlon 64 3700+ San Diego 1GHz HT Socket 939 Processor Model ADA3700CFBOX - Retail
Model #: ADA3700CFBOX
Item #: N82E16819103622
$235.00
G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model F1-3200PHU2-2GBNS - Retail
Model #: F1-3200PHU2-2GBNS
Item #: N82E16820231047
$165.99 -$25.00 Instant $140.99
SONY Beige 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
Model #: MPF920 Beige
Item #: N82E16821103109
$7.99
Western Digital Caviar RE WD2500YD 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #: WD2500YD
Item #: N82E16822136010
$95.00
Western Digital Caviar SE WD3200JS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Model #: WD3200JS
Item #: N82E16822136017
$124.00
Subtotal: $841.34
I intend to put the operating system on 250 gig drive, it has a five year warranty, and is made for 24/7 server operation, which is what I do on IRC. I'll be using my DVD burner (nec3550), a 300gig IDE (ata133) and monitor from my current system as well.
As my IRC channel uses an inforced sharing scheme, the more I have online for others to get, the more I can get for myself. This is why I selected the case and motherboard that I did. The case has plenty of room for adding more drives, and the power supply that will support them. I could see myself adding more sata2 drives and even a couple more IDE's in the future.
On the motherboard, I don't intend to be a gamer or use the sli function of the board, but I really like many of the other features of the board, sata2, gigabit lan, the possibilty of external sata drive at full sata speed.
The reviews on the on board audio have been mixed, I have a soundblaster live card, I could use or I might just get a new card at a later point in time if I'm not happy with it.
The G-skill Ram I'm choosing troubled me, but I decided to spend a little more and get a full 2 gig, then if I upgrade to Windows Vista in the future I'd have the option of getting 2 more sticks to match what already have. They have a CAS of 2.5, and because I don't intend to overclock, I figure they'll be ok.
I have 2 questions I have yet to resolve. The first is the use of Artic Silver heatsink compound. I very much like the sounds of this stuff, but I have also read that it's use can void your CPU warranty. Does anyone know per fact the truth of this? (this rumor I got from a review of the stuff on newegg)
The second question is, as I'm installing Win XP SP2 on my 250 sata drive, there is some mention of having to interrupt the process by hitting F6, and installing sata drivers from floppy? so that this motherboard/xp will see the drive. I've never installed an operating system to a computer that did not have an os on another disk, so I'm in uncharted "terrortory" here.
For my first post to this forum I've gone on quite a bit here, and if my 2 questions would be better posted elsewhere let me know.
Thanks for any advice you may provide.
Model #: ATXA9N/500
$84.99
Model #: A2049
$4.39
$82.99
$65.99
$235.00
$7.99
Model #: WD2500YD
$95.00
Model #: WD3200JS
$124.00
Subtotal: $841.34
