Tom's Hardware > Forum > CPU & Components > Sound Cards > Best sound card for $$$
Forum CPU & Components : Sound Cards - Best sound card for $$$
Best sound card for around $30? Is it better to just stick with onboard sound in this $$$ range?
Sponsored Links
If you want to use surround sound it might help, but like you said, at this price range you're not going to get an enourmous boost in quality.
Try the most expensive Creative card within your budget.
Reply to mesarectifier
I'm going to try this one on my new build - unless I hear a bunch of bad reviews on it in the next 2 weeks.
Diamond XtremeSound
I looked at the low end Sound Blasters, and the 5.1 s seem to have a port that is either Mic or Line in. I need a dedicated line in for my tv tuner.
Reply to GherkinPekul
The Sound Blaster Live! 5.1? Mine both have seperate Line in/Mic connectors.
You're right, I had an older one that did also.
I was thinking of the newer model cards-Audigy SE.
Chaintech AV-710?
Optical out, high SNR stereo only out, and 3 line outs for surround sound. Bitperfect output, or you can manually set a higher sampling rate. Limited to EAX2 for EQ effects. Envy24HT DAC. $20.
Reply to astrallite
I a m building a gaming PC and have maxed my price but don't really want to go with onboard sound either... so what i really need to know is whether this is much better than onboard for the $20 or $30.
Reply to PJ101
What convinces you better, listing what the card is capable of, or just someone saying "this card is good?"
Reply to astrallite
astrallite i have kept up with most computer hardware with the exception of soundcards and really don't know what any of that stuff is. I need something that will make games sound good through either my headphones or my 2 speakers and a subwoofer... I know that EAX1 2 and 3 are options in call of duty but i never got them to work with my onboards... so are they better?
Reply to PJ101
You have 2 decent options in that price range:
http://www.newegg.com/Product/Prod [...] 6829102003
http://www.newegg.com/Product/Prod [...] 6829102176
They are significantly better than onboard sound.
Reply to linux_0
Quote :
EAX is a set of instructions built into the game that provides environmental audio, which is generally a realistic amout of reverb for the room you're in or whatever effect needs to be added by the DSP to make it sound 'like you're really there' etc...
It's not vital, but it's quite cool when it does work.
i got soundblaster live 24bit from newegg for $30. i believe they do sound better than the onboard. but i would also advice you to save up for something better if you could like audigy 2zs or the X-Fi XtremeMusic for about 105$. you wouldn't regard it when you got them. i'm saving up for a x-fi xtreme music now, waiting for a big sale or big rebate.
Reply to amdwilliam1985
Quote :
Very true :-D
EAX is great when it works and when games support it.
Also decent SB hards do audio accelleration in hardware which is better, faster and uses less CPU.
Quote :
Yup.
Even the cheapest SB Live, Audigy SE or whatever, for about $30, is way better than onboard sound.
Onboard sound is just bad.
Reply to linux_0
I bought a used Xtrememusic for $68 with shipping.
Reply to sonnyisthinkn
For a while I thought my Live! sound driver was causing crashes, so I ditched it and ran the onboard (AC'97). It SUCKED. Luckily, the problem wasn't the sound driver, its the chipset, so I got to put my sound card back in. It makes a big difference and even a cheap SB card will be better than onboard.
Reply to theaxemaster
Easy one, Audigy SE for $28.99 at Newegg. Done.
Reply to moparman390
Quote :
Yup :-D
Quote :
and Yup :-D
You can't beat $28.99 for what you get.
I don't understand why they even bother with onboard sound it sucks and just gets in the way.
Reply to linux_0
Thanks for the help guys... looks like its Audigy SE time.
Reply to PJ101
It may be too late, but there's also this offer. It's not too bad, though above the set budget.
Reply to Turjan
Quote :
:-D
It should sound pretty good with a decent set of speakers or headphones!
Good luck :-D
Reply to linux_0
Quote :
The ZS Platinum is EXPENSIVE. I have had the Audigy 2 Value and that's way cheaper and still very good if you're not a pro gamer or high end audio freak or anything. In that case don't buy Audigy 2 series.
Reply to hashv2f16
Quote :
It is quite expensive. The $30 SB value cards work quite well for the price.
Reply to linux_0
There are 1216 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
