Hi, last night i have try some advice:
but last night i just have only 1,5 hours to try, because this computer not at my home, its on my bro's home. and my bro already back to another town for study. so i cant test it all night.
i will bring this comp at my home so i can test it all night. but from tommorow until next 4 or 7 days i'll be in another town, far enough from my town, i have some duty to do from my boss. when i already come back, i will have much time to investigate my K6.
sorry for the inconvenience... if i cant try all of your advices as soon as possible.
here what i tried last night:
1. boot in "command prompt only" with: 1 HD(w98) + vga + all memory without other periperal.
then i do scandisk /all /autofix (without surface scan).
scandisk said ok.
then i type "win" to enter windows mode.
the strange thing is, it doesnt froze up anymore. i can play insaniquarium for a while.
2. i turn off, i connect the second hd (xp), boot into w98 command prompt only and perform scandisk (again without surface scan). scandisc said my 2nd hd (xp) error in directory structure and free space count. and scandisk fix them all.
3. i boot into win xp, xp do chkdsk automically to all my hd, in win xp... long time not froze up (maybe 3-4 minutes, usually its freeze before 30 seconds), but then froze up again
4. i turn off, disconect 2nd HD (XP), back to no 1 configuration, boot to win98, got error message like "bios checksum error". i reset the comp and it froze up again before 30 seconds in windows. what happen with my bios? cmos battery? i never seen this error before.
5. i want try to lowering clock, now mine is 100x3,5. i check the dip switch voltage, i see its 2,2 volt, but in user manual, got sign "*" in 2,8 volt. "*" = denotes default setting.
my question which one is default voltage for a K6-2 350?
in user manual for AMD, the lowest setting are 300mhz (66 x 4,5 or 100 x 3,5), but i see in Cyrix , intel and IDT section, the lowest is 66x2,5 = 166. so which one i should try? with default or lower voltage ?
@ Mitch074
im not try to boot with knoppix yet, but im sure i will try it.
my mobo isnt all integrated. it doesnt have integrated vga or sound.
but i have another mobo tx pro which have onboard vga and sound, but im not sure this old mobo will work because it more than 7 years i dont use it. i use it when im still using Pentium 100.
yes, maybe my K6 is got too warm so i must try downclock it right? i will....
thx
@caboose-1
i want to check all periperal independently, i mean try them all one by one to another comp, but now its very hard to find comp which are compatible with my rig.
i will try vga, hd with my athlon xp comp. but i wont dare to try my old psu on my atlhon xp...its just generic psu 300 & 380w ....thx
@ Grimmy
yes i should try minimum 6 hours of prime95. i'll find it out wheter my system stable or not. just run and go to sleep, see what happen in the morning
@ Anoobis
yupe, i should try my gf4 mx460 with my athlon xp and do surface scan on the HD. thx
@hashv2f16
these problem start before and after i applied contact cleaner. because my friend tell me, his radio/tape can not turn on. then after applied contact cleaner if works again
i do applied contact cleaner then dry it in the sun for 0,5 hours in the daylight. OMG i forgot to tell all of you that i forgot to take off the processor + its hsf. so.... maybe the sun burning some of the K6 transistor? because when i touch the hsf its as hot as my athlonxp's hsf in (+-)60c... "dreaded K6 warm up" ?
please tell me max temp for K6-2?
but, before i applied contact cleanner and dry it in the daylight, my comp is already have problem like i said before.
i'll post the result later after i do your advices.
thx for all your help, interest and attention.
Denny
