Yes No
Ads
Tom's Hardware > Forum > Computer Peripherals > Printers > Epson Stylus C70 problem
Forum Computer Peripherals : Printers Epson Stylus C70 problem
Related Content
Can't find your answer?
Ask!
Archived from groups: comp.periphs.printers (More info?)
I wonder can I use only black cartridge with this printer without buying
color cartridges???
can it work only with black cartridge inside???
tnx
Reply to Anonymous
"Josip" <forgus66@net.hr> wrote in message
news:ctrdoj$94h$1@bagan.srce.hr...
> color cartridges???
> tnx
Nope. Many printers including Epson use underprinting which is laying down a
colour with black. The C70 is pigmented ink and needs the lubrication the
ink provides.
Tony
Got the picture...Print it. JetTec perfect.
http://www.aah-haa.com 30% more ink
http://www.inkylinkusa.com
Reply to Tony
Zaboravi
Pozdrav
adriatic
http://adriatix.hr/
> color cartridges???
> tnx
Reply to Anonymous
Not likely. If you have installed the color cartridges when you used it
earlier and then you removed them, the color heads would all clog up
very badly.
If you only wish to use it as a monochrome printer permanently, it won't
matter, and then I would just have the chips in the color cartridges
reset, so it thinks the color cartridges are full of ink.
If you do plan to print in color again, consider having the old
cartridges refilled with a cleaning fluid for inkjets, and then have the
chips reset, or buy a resetter to do it yourself. This will keep the
heads clear. Set the driver to monochrome printing.
Art
> color cartridges???
> tnx
Reply to Anonymous
The C70 may be pigmented, and it may even use underprinting, although
I'm sure the black is sufficiently dark to work without it, and if the
color cartridges were empty (even with reset chips) they wouldn't print.
Why does a pigment colorant ink printer require lubrication from the ink
in the head?
Art
>>color cartridges???
>>tnx
> ink provides.
> Tony
Reply to Anonymous
- 0 +
"Arthur Entlich" <artistic@telus.net> wrote in message
news:oCtMd.1227$Ox3.546@clgrps13...
> in the head?
> Art
They all do Art - dye as well as pigment - but the pigment inevitably leaves
traces and deposits over time: and the C70 is now some 3 years plus at
least. If you neglect an ink flow the deposits will encrust from within the
head.
Unfortunately you'll have to peel the laminates apart and examine with a
microscope to see this.
Tony
Reply to Tony
The only reason I can think of for a piezo ink head to need lubrication
is if it has ink residue in it, and that is not so much lubrication as
to prevent clogging and dried ink from causing the actuator damage.
If a person wished to run a mono-only C70, or any other Epson, I would
suggest either fully flushing the heads clean and then leaving a dry
empty cartridge just to be there for the cartridge sensor or chip
sensor, or to fill a set of virgin cartridges with something like
non-ammoniated window cleaner with glycol, (a heck of a lot cheaper than
Epson or any other ink cartridge) in the spots that were not needed for
ink, refilling them when they ran out from cleaning cycles. I suppose
one could even put some type of sealing tape on the color heads to keep
them from spitting out any fluid, since Epson heads doesn't seem to be
injured by fully sealed heads (from dried ink, for instance).
Art
>>in the head?
>>Art
> head.
> Tony
Reply to Anonymous
There are 2175 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
1080 and 1200p monitors
By ssddx, 1 day ago:
hello again... remember that an actual screenshot comparing the two would be useless...
Best offers
Top experts
