Strange Win98 Problem
MurPhil
9
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I have a very strange problem! While on the Internet, I did a SEND TO to put
a shortcut on my Desktop for a website that I had been viewing. I noticed
later that the name of this shortcut, as it appeared on the Desktop, was
extremely long (however, the URL that it pointed to was of normal length). I
tried to do a RIGHT CLICK & DELETE on it, and I also tried to CLICK & DRAG it
to the RECYCLE BIN, but Windows wouldn't permit either of these delete
attempts. All I got was an error message that I cannot delete nor move this
shortcut because its name is too long and that I should change it to a
different name. Taking the hint (?), I then tried to shorten its name using
RIGHT CLICK & RENAME, but Windows wouldn't allow this either, again saying
the name was still too long (despite my attempts to rename the shortcut to
just a SINGLE character name!) This is all very odd. I've never encountered
anything quite like this before. I basically can't do anything to delete or
rename this Desktop shortcut, nor to move it off the Desktop. I can only move
it around the Desktop, or run it. Would anyone be able to tell me, please,
how I might be able to permanently delete this shortcut?
Tx ... Murphil
G
Guest
Guest
Jot down the first six letters of the shortcut name. Then go to
Start>Run box, type in command, <Enter>.
If the prompt isn't already at C:\Windows\Desktop>, then do the
following, pressing <Enter> at the end of each line:
cd \
cd windows
cd desktop
(there's a space after cd in each of those commands.)
Once you're at the C:\Windows\Desktop> prompt, do this:
dir xxxxxx*
where xxxxxx is the first six characters in the name of the shortcut.
You should get a file named:
xxxxxx~1.URL
If that doesn't show up, then you probably have separate user profiles.
In that case, do this:
cd ..
cd profiles
cd {YourUserName}
cd desktop
Then try the DIR command again. Once you are certain you see the correct
file, then do this:
del xxxxxx~1.URL
Gary S. Terhune
MS MVP Shell/User
http://www.grystmill.com/articles/cleanboot.htm
http://www.grystmill.com/articles/security.htm
"Murphil" <Murphil@discussions.microsoft.com> wrote in message
news:02403B18-7696-49EB-A9C9-3CADB22C0510@microsoft.com...
to put
noticed
was
length). I
DRAG it
this
using
saying
shortcut to
encountered
delete or
only move
please,
> Tx ... Murphil
Dan
2,208
Wow, you are burning the midnight oil too, Gary. I actually got up after a
few (2) hours of sleep and currently my pumpkin pie is cooling, then I will
have a small slice and it is off to bed for me for a few (3-5) hours more of
sleep. -- :>
I do best with 7 hours but will tolerate as little as 3 hours as long as it
is not a pattern -- grinning and bearing it <no offense Robear -- just a
joke -- you can make one of me if you want.>
"Gary S. Terhune" <grystnews@mvps.org> wrote in message
news:u6OOWFwHFHA.588@TK2MSFTNGP15.phx.gbl...
: Jot down the first six letters of the shortcut name. Then go to
: Start>Run box, type in command, <Enter>.
: If the prompt isn't already at C:\Windows\Desktop>, then do the
: following, pressing <Enter> at the end of each line:
: cd \
: cd windows
: cd desktop
: (there's a space after cd in each of those commands.)
: Once you're at the C:\Windows\Desktop> prompt, do this:
: dir xxxxxx*
: where xxxxxx is the first six characters in the name of the shortcut.
: You should get a file named:
: xxxxxx~1.URL
: If that doesn't show up, then you probably have separate user profiles.
: In that case, do this:
: cd ..
: cd profiles
: cd {YourUserName}
: cd desktop
: Then try the DIR command again. Once you are certain you see the correct
: file, then do this:
: del xxxxxx~1.URL
: Gary S. Terhune
: MS MVP Shell/User
: http://www.grystmill.com/articles/cleanboot.htm
: http://www.grystmill.com/articles/security.htm
: "Murphil" <Murphil@discussions.microsoft.com> wrote in message
: news:02403B18-7696-49EB-A9C9-3CADB22C0510@microsoft.com...
: > I have a very strange problem! While on the Internet, I did a SEND TO
: to put
: > a shortcut on my Desktop for a website that I had been viewing. I
: noticed
: > later that the name of this shortcut, as it appeared on the Desktop,
: was
: > extremely long (however, the URL that it pointed to was of normal
: length). I
: > tried to do a RIGHT CLICK & DELETE on it, and I also tried to CLICK &
: DRAG it
: > to the RECYCLE BIN, but Windows wouldn't permit either of these delete
: > attempts. All I got was an error message that I cannot delete nor move
: this
: > shortcut because its name is too long and that I should change it to a
: > different name. Taking the hint (?), I then tried to shorten its name
: using
: > RIGHT CLICK & RENAME, but Windows wouldn't allow this either, again
: saying
: > the name was still too long (despite my attempts to rename the
: shortcut to
: > just a SINGLE character name!) This is all very odd. I've never
: encountered
: > anything quite like this before. I basically can't do anything to
: delete or
: > rename this Desktop shortcut, nor to move it off the Desktop. I can
: only move
: > it around the Desktop, or run it. Would anyone be able to tell me,
: please,
: > how I might be able to permanently delete this shortcut?
: > Tx ... Murphil
G
Guest
Guest
For at least a week, now, I've been going to bed in the late morning
(after 9 am) and getting up in the afternoon. "Last night" I went to bed
early--around 7am. I've been writing a lot of script and juggling a new
database for our business.
Gary S. Terhune
MS MVP Shell/User
"Dan" <spamyou@user.nec> wrote in message
news:e4m1XWwHFHA.2752@TK2MSFTNGP12.phx.gbl...
after a
will
more of
> sleep. -- :>
Dan
2,208
Wow, you certainly are busy. Fridays are my Sabbath day to relax, recharge
and rejuvinate as well as Sunday off from work for church stuff. I usually
work Saturdays at Target Corporation. Anyway, great problems at my store in
Tucson, Arizona on Friday and they called me at 9am to see if I could come in
to work to put out fires (help solve their problems) and other stuff. I
smartly refused -- had a great time on Mt. Lemon at a wonderful cafe called
the Mount Lemon Cafe that serves delicious home made pies at an elevation of
about 8,000-9,000 feet above sea level. Next, I went to a friends 23rd
birthday party named Cody and we went to a steakhouse. The dinner rocked and
I had two glasses of Francis Ford Coppola wine and I was very happy and
pleased with myself. I gave the restaurant a good tip as well as providing
some personnel information in exchange for me being on their VIP (Very
Important Person) list and being on their mailing list to get discount
coupons. It is a brand new restaurant called Flemmings that has excellent
prime steak. Anyway, I can hardly believe that it is already March. Whew,
time sure does fly when you are having fun. BTW, I talked to Microsoft on
Saturday and the technical support guy that I talked to told me how the
janitor called him at 4am to ask him to come into work --- needless to say he
was ticked and told the janitor never to call him that early again and I
thought I had it bad by being disturbed at 9am on my day off!
LOL!!
news:%23t2cudwHFHA.3628@TK2MSFTNGP15.phx.gbl...
: For at least a week, now, I've been going to bed in the late morning
: (after 9 am) and getting up in the afternoon. "Last night" I went to bed
: early--around 7am. I've been writing a lot of script and juggling a new
: database for our business.
: Gary S. Terhune
: MS MVP Shell/User
: "Dan" <spamyou@user.nec> wrote in message
: news:e4m1XWwHFHA.2752@TK2MSFTNGP12.phx.gbl...
: > Wow, you are burning the midnight oil too, Gary. I actually got up
: after a
: > few (2) hours of sleep and currently my pumpkin pie is cooling, then I
: will
: > have a small slice and it is off to bed for me for a few (3-5) hours
: more of
: > sleep. -- :>
G
Guest
Guest
Yes, INDEED, contact them, & give them a piece of my mind! No! Make it
my gall bladder!
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
news:ug8dCfDIFHA.580@TK2MSFTNGP15.phx.gbl...
| PCR, do you need me to contact Macromedia to get them to change.
:> -- I am
| on the warpath and want companies to meet consumer's needs as well as
meeting
| business's needs and finally the government's needs also.
| "PCR" <pcrrcp@netzero.net> wrote in message
| news:uSOKxI8HFHA.2700@TK2MSFTNGP09.phx.gbl...
| : He said his was an URL he downloaded. Scandisk could possibly do it
too.
| : But I don't quite recall whether it gives an option to delete, or
just
| : to "fix". I have two Macromedia files or folders that always get
flagged
| : by Scandisk. Once, I asked it to fix them, but it only moved them up
| : higher in the folder tree. Next time Macromedia Flash ran, it put
both
| : back where they were before! I HATE those two! Now, I just ignore
them.
| : Ah, here they are...
| : The
C:\WINDOWS\APPLIC~1\MACROM~1\FLASHP~1\MACROM~1.COM\SUPPORT\FLASHP~1
| : folder could not be opened in MS-DOS mode because its complete short
| : name
| : was longer than 66 characters.
| : Resolution: Ignore this error and continue
| : Results: Error was corrected as specified above.
| : The
C:\WINDOWS\APPLIC~1\MACROM~1\FLASHP~1\MACROM~1.COM\SUPPORT\FLASHP~1\SYS
| : name
....snip
