As everyone knows AM2 is a lot less efficient in extracting bandwidth from DDR2 and it made me wonder about something concerneing memory dividers.
Most 939s are CPU speedmultiplier, but if AMD increases HTT to 333MHz and not 400MHz, then they will have an issue the the divider because DDR 800 is not a multiple of 333, so I was wondering if anyone has any info on how they are handling this issue.
The speeds of HyperTransport and that of Memory can be independent of one another, such as having a base HTT of 333MHz and have memory run @ 400MHz is VERY possible, and plausible. AMD, if they plan to run 333MHz HTT (Rumored 400MHz for FX's) than they can EASILY run the Memory Bus @ 400MHz or higher (For such as DDR2-1066) and not run into problems that Intel based platforms may.
BTW, that "inefficiency" is due to the Modules and ES, expect better results in the future on launch day.
~~Mad Mod Mike, pimpin' the world 1 rig at a time
Thx, Mike. I told them all you weren't an a-hole. j/k. anyway, I was just curious if the divider would be affected if HTT was at 333MHz. I also noticed that I don't remember seeing the Anand tests mention the faster HTT. Do you know if the chip he used was at 200 or 333?
Having a Memory divider, in my experience with AMD64's, DOES affect performance, but positively. But, by this I mean setting a RAM divider BELOW that of the HTT speed, this has proven to give larger inprovements in Memory Write speeds, while maintaining the same average Memory Read speeds as 1:1. If the divider is changed from 1:1, it will NOT affect the A64 negatively AT ALL, at best, it will change it positively, and at worst, it won't affect it at all.
The rumor was that AMD would run the AM2's of Windsor (the X2's and A64's) @ 333MHz Base while the FX's @ 400 (To run DDR2-667 and DDR2-800 respectfully) I still have not seen conclusive evidence of either one, though the ES of Toms back in February I believe were running 200MHz, though I am not positive.
