Hello all,
I have recently gotten a Sapphire X1900XTX 512mb vid card and I understand that when in "2D Mode" that the cards slow themselves down, I just dont know how much, so when in windows it should be slowed or (underclocked) correct? If so can you guys check and see what yalls temps are in the CCC. I just want to c if mine is where it should be at cause it seems low.
my speeds when I check CCC are 500/594 (core/mem)!
P.S. For all of you overclockers out there, what programs are you using for OC'ing...any links for downloads of the programs would be great!
Thank you all in advance for your help!
Best,
3Ball
Antec NeoHE 550w PS
Gigabyte GA-K8N Pro
AMD Athlon 3700+ Sandy - "Arctic Freezer 64"
2gb (2x1gb) Patriot Performance Memory (2.5-3-2-5)
(2x120gb WD SATA HD's) - Raid 0
Best,
3Ball
Antec NeoHE 550w PS
Gigabyte GA-K8N Pro
