Archived from groups: microsoft.public.win98.gen_discussion (More info?)
My System:
Tyan S2080 Tomcat 1815T
Intel PIII 1Gz
Antec 350w
Plextor CD/RW
Western Digital 40.GB 7200 ata100 HD
Western Digital 20.GB 7200 ata100 HD
ATI ALL-IN-WONDER 128 PRO AGP 32MEG
SOUND BLASTER LIVE! VALUE
Win98se
I installed the above new mobo, cpu and psu. After initial setup, the BIOS
recognized all my drives and the cpu. I got no error beeps.
When trying to start up, I got a black screen with the text: can not read
drive C.
Drive C, as seen by my bios, is my master drive WD20gig.
Not knowing what else to do, I proceded to do a format and clean instal of
win98 using the procedure I have successfully done before from the Microsoft
Knowlege Base.
After running fdisk and deleting and creating an active primary dos
partition. I inserted my Win98CD as per instructions. The windows scandisk
gave me the following message:
ScanDisk cannot read from the last cluster on drive C. This clsuster is
eather damaged, or your system is not condigured properly. Crive C may need
to have Logical Block Addressing (LBA) enabled to work pproperly. or its
disk partition ay be incorrectly marked as a non-LBA partition. Data loss
can occur if your LBA setting or disk partition type for this drive is
misconfigured.
Check your computer's BIOS setup utility, or contact your computer
manufacturer, or have your computer checked by a qualified computer hardware
technician.
If you ar sure your drive is configured correctly, click Continue to have
ScanDisk check drive C for errors.
I checked the BIOS to make sure LBA was enabled.The BIOS choices are "auto"
and "disable". "Auto" says it means enabled, and this is what was already
set.
I figured that my harddrive was bad, so I purchased a new Maxtor 80gig
ATA133.
I switched out my WD for the Maxtor, and my BIOS recognized it. I used the
Maxtor software to creat 2 partitions. 1-20gig 2-60gig. Per the Maxtor
instructions, I procceded to install win98. I got the same ScanDisk message
as above.
I decided to start over using fdisk on the Maxtor.
I started to delete partitions and reformat using fdisk insead of the Maxtor
program and fdisk saw a total size of 12624mg rather than the actural size
of 80000mg.
This is where I'm at at the moment. What shall I do next?
"jg" <jg87@(nospan)verizon.net> wrote in message
newsLkYd.100$qN3.80@trndny01...
> My System:
> Intel PIII 1Gz
> Antec 350w
> Plextor CD/RW
> Win98se
> drive C.
> Microsoft
> Knowlege Base.
> need
> misconfigured.
> hardware
> technician.
> "auto"
> set.
> ATA133.
> message
> as above.
> Maxtor
> size
> of 80000mg.
from "computing net"
If you used the Fdisk bundled with Win98 to partition this disk then that is
your problem. That version on Fdisk will not work properly with disks larger
than 64GB. You need the newer version of Fdisk. Unfortunately you will need
to delete your present partitions and creatd new one using the newer Fdisk.
If Fdisk can't delete the existing partitions, use Delpart to do that and
then fdisk to create new. Find the new Fdisk and Delpart here:
See if you executed all the steps:
1. Set Master/Slave jumpers of all the drives: in position "Master" if
the drive is connected to the end of the ribbon cable, and in position
"Slave" for the drives connected to the middle of the cable.
2.Switch your computer on, enter BIOS setup, and disable "Virus Warning"
here (the exact name and position of this item depends on the
motherboard).
3. Make sure all the HDDs in BIOS are shown correctly. Set boot sequence
"A: then C:"
4. Exit BIOS setup with saving settings, boot from the standard
Windows-98 Startup Disk (diskette) -- with or without CD-ROM support,
and partition HDD using Fdisk. If you have not replaced an old Fdisk
with the new one before,
http://support.microsoft.com/defau [...] -us;263044 -- you can use the old Fdisk still: don't pay attention to the sizes it
shows, and partition the drive not in gigabytes, but in percents (say,
25% for primary partition, 100% of the rest -- for extended partition,
and 100% of the extended partition -- for the second logical drive).
5. Restart, boot from the standard Windows Startup Disk (diskette)
again, with CD-ROM support, and run:
format c:
When formatting is finished -- format the other(s) drive(s):
format d:
etc.
(Formatting of such big logical drives can take tens minutes).
6. Run Win98 installation from CDROM.
Mikhail Zhilin
http://www.aha.ru/~mwz Sorry, no technical support by e-mail.
Please reply to the newsgroups only.
On Fri, 11 Mar 2005 17:42:06 GMT, "jg" <jg87@(nospan)verizon.net> wrote:
>My System:
>Intel PIII 1Gz
>Antec 350w
>Plextor CD/RW
>Win98se
>drive C.
>Knowlege Base.
>misconfigured.
>technician.
>set.
>ATA133.
>as above.
>of 80000mg.
See below for reply:
> My System:
> Intel PIII 1Gz
> Antec 350w
> Plextor CD/RW
> Win98se
> drive C.
Microsoft
> Knowlege Base.
need
> misconfigured.
hardware
> technician.
"auto"
> set.
> ATA133.
message
> as above.
Maxtor
size
> of 80000mg.
12GB seen is normal. Its the remainder, after 64GB, when formatted. Its an
fdisk problem. Use the Maxtor formatting software instead.
The problem appears consistent by failing to read the last cluster on both
hard drives. Start fresh. Be sure you're using 80 wire ide ribbon cables,
18" in length and are firmly seats on both ends. Reseat your memory
modules. Check the memory timing in the bios. Irregardless, reset the
cmos, see the TomCat manual for this. Be sure the cmos battery is up to
voltage with a multimeter. Be sure the jumpers are configured correctly on
the HDs. For now, physically remove the sound card. Check the CHS and
landing zone requirements for the Maxtor drive at the Maxtor site, and input
manually. Yes, you want LBA. For now, turn PNP OS off in the bios by
indicating "N". Physically remove the "Western Digital 40.GB 7200 ata100
HD" out of the system for now.
If scandisk problem continues, run setup without scandisk. Input "setup /?"
for instructions on how to do this. If you're able to install a
non-protesting windows, and have imaging software. Image the installation
to the alternate partition for safekeeping. Don't do anything else until
you do this, it will save you much time if you have to install again.
Consider running one primary, active partition, 20GB. Make the remainder an
extended partition with one logical partition. And dont expect the
remainder to be 60GB, it will be less due to partitioning and formatting
overhead requirements.
There may be nothing physically wrong with the "Western Digital 20.GB 7200
ata100 HD".
"Lil' Dave" <spamyourself@virus.net> wrote in message
news:exBqBvuJFHA.484@TK2MSFTNGP15.phx.gbl...
> > My System:
> > Intel PIII 1Gz
> > Antec 350w
> > Plextor CD/RW
> > Win98se
BIOS
read
> > drive C.
of
> Microsoft
> > Knowlege Base.
scandisk
> need
loss
> > misconfigured.
> hardware
> > technician.
have
> "auto"
already
> > set.
> > ATA133.
the
> message
> > as above.
> Maxtor
> size
> > of 80000mg.
an
cables,
on
input
an
> ata100 HD".
Thanks for all the input. There was nothing physically wrong with either
drive. I tested both of them in another computer using scandisk.
I did as you suggested and reset the memory and reset cmos. I tried to
install windows using only the WD20 with the same unsuccesful results, so I
wrote Tyan asking for advice and how to get a new momo replacement.
