Tom's Hardware > Forum > CPU & Components > Sound Cards > Can't get enough volume from my laptop speakers, help
Forum CPU & Components : Sound Cards - Can't get enough volume from my laptop speakers, help
I've got a DELL Latitude D410.
I can't get enough volume from the speakers.
I've raised every volume control I can find and it's still barely audible.
Surely there must be a way to raise the volume more or to remove this cap?
I'm grateful for any help in this matter.
Sponsored Links
Hi Caintommy,
With regards to your questions about the speaker volume, you may want to do the following:
1) Check the connection between the speakers and the PC. Are they secure? If not, secrue them.
2) Also check if within the Windows environment - whether you've enabled the sound to maximum. Sometimes you need to up the master volume and also the WAV file volume.
3) The other thing to do is to try the speakers with a normal Hi-Fi or another computer. Do you get the same problem? If you do, then its the speakers that are defective. If not, then the Dell has a problem. You may want to get an additional sound card to help matters.
Reply to timberwolf1
Laptop speakers aren't very powerful. There are media player EQs that can effectively double the volume by playing with the voltage, but it would certainly sound very bad at that point. For a few dollars you could get something at your local electronics store that would turn up a lot louder than built-in laptop speakers.
Reply to astrallite
Yup yup, try setting the EQs to full on all bands, it might sound crap but laptop speakers do.
Reply to mesarectifier
There are 551 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
