Archived from groups: microsoft.public.win98.gen_discussion (More info?)
In order that we might better dissect the obvious problem that is
KB891711.EXE, I'd like to request any and all persons who have
encountered the problems to please do some tests for me and report the
results according to the schema below. My goal here is to collect data
in a standardized and methodical manner for MS techs to use. Trying to
pick through the somewhat haphazard anecdotal evidence that has been
posted thus far would make the task more difficult. Please refrain from
additional discussion of the issue in this thread. I'd like to keep it
clean of speculation, etc. I'm sure that if the techs want more specific
tests done, they'll ask, and I'm sure, also, that they will likely
review other posts to this NG for background.
1. How do you connect to the internet? Dial-up, DSL, cable?
2. Without changing anything, and with your normal background apps
enabled, when and how do errors occur, and what are the exact, verbatim
details of these errors? In the case of non-BSOD errors, include
Registers, please.
3. What, if any, tricks have you discovered that allow you to bypass
errors (other than disabling anything, including KB891711.EXE in
MSCONFIG or otherwise killing processes.)
4. Using your AV settings, disable any real-time or background
functions. Then go into MSCONFIG and disable everything in the Startup
tab *except* KB891711.EXE. Physically disconnect your system from any
internet connection, then restart. Try various programs, most especially
IE or whatever your default browser is. Yes, I know you won't get
anywhere, yet.
5. Whether or not errors occur in step 4, reconnect your system to the
internet and attempt to go online. Report any errors. (You may want to
restart again before this step.) Do not stay online if you actually make
it there. No AV and no Firewall mean you're a ripe target for invasion.
Quit your browser and then immediately disconnect the physical
connection. Go into MSCONFIG and re-enable your firewall, restart and
reconnect to the internet, then test. Next, test with AV enabled. Then
progressively re-enable the rest of the items in MSCONFIG, testing at
each juncture.
If any Windows ME users are lurking and have problems with KB891711.EXE
and want to participate, be sure not to disable items in MSCONFIG
related to System Restore (I *think* that's the ones marked by an
*asterisk, but I'm not certain.)
Gary S. Terhune
MS MVP Shell/User
http://www.grystmill.com/articles/cleanboot.htm
http://www.grystmill.com/articles/security.htm
"Gary S. Terhune" <grystnews@mvps.org> wrote in message
news:usbTRpKKFHA.3336@TK2MSFTNGP10.phx.gbl...
> results according to the schema below....
Dial-up.
> Registers, please.
Laptop running Windows 98SE. Went to Windows Update and installed the two
latest updates (Q?250 and Q891711), one at a time and in that order.
Everything seemed fine, then my dialup connection terminated during an AVG
virus-definition download. Attempting to reconnect resulted in "no dial tone
detected" errors in DUN, even though the phone line was connected and OK. My
Active Desktop (a local HTML file) then turned into the WSOD; clicking on
"Restore Active Desktop" caused my system to stop responding to the mouse
and keyboard. Ctrl-Alt-Del having no effect, I had to turn the PC off and
back on.
On reboot, everything seemed fine after the obligatory Scandisk until after
the login prompt, when the WSOD desktop appeared and my computer locked up
after some but not all of my background programs had started up. Repeated
the hard reset a couple of times, with the same result.
Finally booted into Safe Mode (F5 is our friend) and removed 891711 from my
system via Add/Remove Programs. Restarted the PC, and everything was fine.
Ran my anti-virus and anti-spyware programs, nothing found.
> anywhere, yet.
> each juncture.
> Gary S. Terhune
> MS MVP Shell/User
the
data
to
from
it
specific
verbatim
> Registers, please.
Startup
especially
> anywhere, yet.
the
to
make
invasion.
Then
> each juncture.
KB891711.EXE
> Gary S. Terhune
> MS MVP Shell/User
On Mon, 14 Mar 2005 07:27:25 -0800, "Gary S. Terhune"
Dialup
>Registers, please.
no errors because I unchecked KB891711, and I'm afraid to recheck it
no tricks
>anywhere, yet.
I'm not daring enough to do that
>each juncture.
not doing that either because, when IE crashes, I don't just go to the
blue screen. Instead, my whole system freezes and won't do one darned
thing until I flip the switch on the computer, then turn it back on.
I'm not going to continue flipping the switch and make a bad thing
worse.
While many of you find computer problems like this to be intriguing, I
find them frightening.
Beth
It appears that my first reply did not come through, so I'll summarize
my experience. I use cable. After I downloaded KB 891711 and 888113,
when I rebooted as soon as the quick start menu loaded, I got the blue
screen and an error message. Unfortunately, I did not write the error
message down, altho (as will be noted) I got it several times, but I
think it was 0X8007003. Each time I rebooted, I got the same result.
So, I went into Safe Mode and used System Restore to go back before the
download, and everything was OK; however, my download history noted
that the two updates were successfully downloaded. The next day I got
the Update alert and, foolishly, updated them again, with the same
result, and the same remedy. This time my update history noted two
successful downloads.
I checked MSCONFIG for starting programs and neither KB was listed.
I'm confused here. The updates were noted to be successful, but each
time I went back before the updates. Does that mean the downloads were
successful, but they haven't been installed? They are not in my start
menu and a search for them revealed nothing.
I'm not going to do the rest as my puter is working now and I intend to
keep it that way.
Gary,
You said that KB891711 was an "obvious problem" and it sounds like it is for
many users. However, for my computer -- other than the odd fact that it
loads at startup and shows in MSCONFIG -- I have seen no effect of any
kind. I'm a Win98SE user, cable hookup, Firefox browser. Hope my good
fortune holds up!
> Registers, please.
> anywhere, yet.
> each juncture.
> Gary S. Terhune
> MS MVP Shell/User
> ...The next day I got the Update alert
Are you running Win98? Do you have Windows Critical Update Notification
Utility (http://support.microsoft.com/kb/224420) installed?
~Robear Dyer (PA Bear)
MS MVP-Windows (Shell, IE/OE) & Security
In Memoriam, MVP Alex Nichol (1935-2005)
http://www.microsoft.com/windowsxp [...] ichol.mspx
> keep it that way.
Hello, Gary, et. al.,
RE: WinME machines
The only item in msconfig/Startup related to System Restore under WinME is
the *statemgr, the State Manager responsible for supervising the
launch/execution of both System File Protect and System Restore. Unchecking
*statemgr in msconfig will disable both functions.
There is an extensive discussion of the KB 891711 problem, particularly in
....windowsme.general, where it is yet quite uncertain what the important
contributing cause/s is/are. An earlier suggestion that only early AMD
cpu's of <700 MHz are responsible appears not to be true.
Another suggestion is tentatively implicating certain BIOS's, as seen in an
earlier Win Update problem.
Other less probable causes include the chipset and the video adapter/driver.
We believe we have ruled out NAV and Live Update as the culprit.
HTH,
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
http://www.microsoft.com/athome/se [...] fault.aspx
In Memorium: Alex Nichol
Your cooperation is very appreciated.
> Registers, please.
> anywhere, yet.
> each juncture.
> Gary S. Terhune
> MS MVP Shell/User
Archived from groups: microsoft.public.win98.gen_discussion,microsoft.public.windowsme.general (More info?)
X-Post to WinME General.
Jack, would you and the others please consider pinging your Lead(s) about
this problem? Several of us are trying to 'kick it up a notch' by doing so.
Thanks.
> RE: WinME machines
> Unchecking *statemgr in msconfig will disable both functions.
> an earlier Win Update problem.
> adapter/driver.
Thanks for the report, Jack! Sounds like you guys have it about as well
nailed down as anyone else, <g>.
Reason I cautioned against disabling *statemgr is that disabling SFP and
SR also deletes the "restore points" (right?)
Gary S. Terhune
MS MVP Shell/User
"Jack E Martinelli" <jemartin_DELETE@NO_SPAM_gis.net> wrote in message
news:%236G$VUNKFHA.732@TK2MSFTNGP12.phx.gbl...
> RE: WinME machines
WinME is
Unchecking
particularly in
important
AMD
in an
adapter/driver.
Ten four, Big Guy.
I suspect MS has heard plenty already.
"PA Bear" <PABearMVP@gmail.com> wrote in message
news:%23sbylYNKFHA.3420@tk2msftngp13.phx.gbl...
so.
> Thanks.
> > RE: WinME machines
is
in
> > adapter/driver.
Normally DSL, sometimes cable, sometimes dial-up via dial-up networking (NOT an installed bloatware application). DUN still functions normally.
Registers, please.
BSOD only when using a small, common Win98 application kown as "Enditall". (I've used this same application for many years and have not had any BSODs with it until the last two critical updates were installed. I decided to test it after I noticed the running process "kb 891711" which led me to Google it and discover a newsgroup post suggesting that this process interfears with programs like Enditall that access Windows Explorer.)
No errors. No tricks. Serious problem: BSOD with Enditall.
anywhere, yet.
Problem not browser (IE6) related. No AV used or needed. Have external firewall, plus good ISPs (Covad or MSN for msn.com email) blocking most SPAM and viral attachments, and an understanding of file extensions and potential dangers.
each juncture.
No AV; firewall is external. Since my computer is old and slow (133MHz) I keep my msconfig down to about 15 processes most of which are for small useful utilites. Since Enditall is not a background process, none of the items in the msconfig list contribute to the BSOD.
Gary S. Terhune
MS MVP Shell/User
Only KB891711 would show up at MSConfig, but both would show at "Control
Panel, Add/Remove Programs, Install/Uninstall tab"...
(a) Windows 98 KB891711 Update
(b) Windows 98 Q823559 Update
(c) Windows 98 Q840315 Update
(d) Windows 98 Q888113 Update
(e) Windows 98 Q890175 Update
...., somewhere in that bunch. BUT, I am Win98SE. You may be WinME, if
you have GoBack, per Terhune.
I believe you will not find them there. You have uninstalled them, I
think, & Windows Update knows it, because it offers them again. (Man,
they should have pulled it by now, though!)
YET, it's History button is confused. Perhaps GoBack did not recover the
file that is your History, which I THINK is...
"C:\Program Files\WindowsUpdate\V4\iuhist.xml"
Was GoBack supposed to get that one? What is the date on yours? Mine is
3/10/05, the date I took those last two, acc. to...
"C:\WINDOWSWindows Update.log"...
........Quote..............
2005-03-10 00:23:08 05:23:08 Success IUENGINE Downloaded file
http://download.windowsupdate.com/ [...] 057046.EXE
2005-03-10 00:23:08 05:23:08 Success IUENGINE Local path
h:\WUTemp\com_microsoft.891711_98_SP1_WinSE_295\Windows98-KB891711-ENU.E
XE
2005-03-10 00:23:10 05:23:10 Success IUENGINE See iuhist.xml
for details: Download finished
........EOQ.................
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
"irvingr5" <irvingr5@comcast.net> wrote in message
news:1110823068.105358.238070@o13g2000cwo.googlegroups.com...
the
were
to
| keep it that way.
The machines I see the problems on at work are Win98SE, Dell computers with Intel
processors of 1GHz or more, integrated Intel video adapter/driver. I will check the
exact info and the BIOS versions this week if I can get to them. Note that there
are three identical Dell computers there, and only two of them exhibited the blue
screens. NAV and LU are not on any of the machines. No third-party
firewall....they are on a network using a Netgear router with a built-in firewall,
broadband connection (RoadRunner).
Glen Ventura, MS MVP Shell/User, A+
~ In memory of our friend, MVP Alex Nichol ~
http://aumha.org/alex.htm
http://dts-l.org/goodpost.htm
> RE: WinME machines
> HTH,
> > Registers, please.
> > anywhere, yet.
> > each juncture.
> > Gary S. Terhune
> > MS MVP Shell/User
Correct!
"To reset System Restore:
System | Performance | File System | Troubleshooting and check "Disable
System Restore", Apply and IMMEDIATELY reboot. This will flush your restore
folder and erase all checkpoints, then,
System | Performance | File System | Troubleshooting and uncheck "Disable
System Restore", Apply and again IMMEDIATELY reboot. This should now
automatically create a new checkpoint immediately following the restart.
Finally adjust the space allocated to the restore folder,
System | Performance | File System | Hard Disk and adjust the restore slider
to your preferred setting.
Mike Maltby MS MVP "
news:%23oahXZNKFHA.3832@TK2MSFTNGP12.phx.gbl...
> Gary S. Terhune
> MS MVP Shell/User
> > RE: WinME machines
> WinME is
> Unchecking
> particularly in
> important
> AMD
> in an
> adapter/driver.
Glen, if you are seeing three identical machines with the same BIOS's and
only two are exhibiting the 891711 problem then that rather rules out
(tentatively) Mike Malby's suggestion that the issue is some BIOS timing
problem, as seen earlier with the first released Prescott and new Celeron
cpu's and the early OEM-BIOS's.
Please confirm that the Dell/Intell machine BIOS's are indeed identical,
i.e., no flashed items.
Your observations also kill the "only-AMD cpu" connection.
Perhaps a close examination of the Belarc Advisor and Everest reports for
the three machines will reveal the cause ...
"glee" <glee29@spamindspring.com> wrote in message
news:%23cEIjfRKFHA.3332@TK2MSFTNGP15.phx.gbl...
with Intel
check the
that there
the blue
firewall,
<SNIP>
Glen I wanted to ask you this before, and don't want to sidetrack this thread
much, but it's delightfully interesting that a company still uses 98SE and my
wondering is not a trick question but would sincerely like to know the
reasons surrounding it. ..perhaps it's just a small company and what works
well and is very stable and the employees are used to it so then why
change it creating the common 'change confusion' ? ..or is there more?
Thanks much,
Rick
I have ME and GoBack would not give me any prior date, so I used System
Restore. I don't know why GoBack could not, and it could not twice,
unless it's because System Restore is active. You're right, since I
went back before the installations both times, neither of those patches
were installed, although my History shows that they were both
successfully installed. Well, they were, but by System Restore, I
uninstalled them.
I got the reminder again today, and did install KB888113, but not
KB891711, with no problems. Am I safe with just this one?
Glee, I have ME, Dell, Pentium III with speed of 800 mghz, and I
have this problem.
While this issue is happening in Win98 and WinME (with Win2K indicated
elsewhere), might I suggest that a WinME-specific newsgroup would be a more
logical place for you?
news://msnews.microsoft.com/microsoft.public.windowsme.general
> have this problem.
I connect using DSL and don't seem to have any problems,But my P.C. take
double the usual time to boot-up and it seems to take a long time for all the
icons to appear on the desktop. On other web sites I looked into it seems
that uninstalling the update doesn't help, since the problems caused by it
persist, In my case I took it out of the start-up menu with msconfig but upon
rebooting, when I pressed control-alt-delete on the empty screen, it still
shows up as a running process, and it is still slow in booting up. I hope
Microsoft comes up with a fix soon ....because they are making a good case
for me to buy a Mac......if they weren't so dammed expensive.......I guess
you get what you pay for.......................
> Registers, please.
> anywhere, yet.
> each juncture.
> Gary S. Terhune
> MS MVP Shell/User
You have no choice but to be safe with just one, until MS fixes the
other. BUT, the write-up on the KB891711 vulnerability is horrific. So,
watch what you click for a while, & keep your virus scanner up-to-date.
Well, it looks like you've uninstalled KB891711, if the site continues
to offer it to you. But, I wonder, how do you compare against what
Chauvin has said are the Registry entries & files of the thing. Of
course, this is for Win98SE & may naturally be different for you. Maybe,
just do a search for the files he mentions...
news:eaKRLVwJFHA.3336@TK2MSFTNGP09.phx.gbl
.........Quote...............
The install is really really a simple one though, and just for notation
here
is exactly what the simple install does, and from this it's easy to make
sure the uninstall is complete if ever need be:
(for files - only 3 were added and no other file changes were made)
C:\WINDOWS\INF\QFE\W98\
891711UN.INF
C:\WINDOWS\SYSTEM\KB891711\
KB891711exe
Q891711.dll
(and for the registry the install only Added a few entires - it made no
other changes)
[HKEY_LOCAL_MACHINE\Software\Microsoft\Active Setup\Installed
Components\{2cd1b477-8d46-4b86-b7dc-13fb65fb5914}]
@="Windows 98 KB891711 Update"
"IsInstalled"=dword:00000001
"Locale"="EN"
"Version"="4.10.0.2222"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunService
s]
"KB891711"="C:\\WINDOWS\\SYSTEM\\KB891711\\KB891711.EXE"
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Setup\Upda
tes\W98\UPD891711]
"C:\\WINDOWS\\SYSTEM\\KB891711\\KB891711.EXE"=""
"C:\\WINDOWS\\SYSTEM\\KB891711\\Q891711.DLL"=""
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\
891711]
"DisplayName"="Windows 98 KB891711 Update"
"UninstallString"="RunDll32 advpack.dll,LaunchINFSection
C:\\WINDOWS\\INF\\QFE\\W98\\891711UN.INF"
.........EOQ.................
PCR
pcrrcp@netzero.net
news:1110912560.730863.168630@l41g2000cwc.googlegroups.com...
System
patches
| uninstalled them.
PA, do you know what happens if one were to delete "C:\Program
Files\WindowsUpdate\V4\iuhist.xml". Would the site generate a new one or
blow up?
PCR
pcrrcp@netzero.net
news:%239s23INKFHA.1392@TK2MSFTNGP10.phx.gbl...
Notification
summarize
888113,
blue
error
result.
the
got
each
were
start
to
| > keep it that way.
Door #1, I suspect.
~PA Bear
> blow up?
I will try to get the info, but it may be days before I can get on those machines
again.
news
s9gZFWKFHA.2736@TK2MSFTNGP09.phx.gbl...
> with Intel
> check the
> that there
> the blue
> firewall,
> <SNIP>
Small company. They bought an H-P ME computer when ME came out, and were not
impressed, so on subsequent machines ordered (from Dell), they specified Win98SE.
They bought a Compaq a year ago with XP SP1, then just a few months ago bought two
Dells with XP SP2. So we now have Dells with 98SE and with XP SP2, along with the
H-P ME, and a Compaq XP which has recently been upgraded to SP2.
"Rick Chauvin" <justask@nospamz.com> wrote in message
news
qzJjPWKFHA.3184@TK2MSFTNGP09.phx.gbl...
> Thanks much,
> Rick
I should try it one day. I wonder whether it would be properly filled in
or left empty.
PCR
pcrrcp@netzero.net
news:u9oBGubKFHA.244@TK2MSFTNGP12.phx.gbl...
| Door #1, I suspect.
| ~PA Bear
one or
| > blow up?
> <snip>
> Gary S. Terhune
> MS MVP Shell/User
I know you're asking for responses from those having problems but perhaps
you might also find it useful to hear from those of us who are not. I have
all the latest updates and am having no problems. I running:
Windows 98SE
HP Pavilion 8380
400 MHz Pentium II
224.OMB RAM
40 GB
Compaq 7470, 533MHz AMD K6-2, Win98SE, IE6 SP1, fully updated.
Have the problem.
Can you...?...
"START, Run, MSInfo32, Software Environment, Running Tasks"
Post what you see for these...
Rnaapp.exe 4.10.2222 Microsoft Corporation Dial-Up Networking
Application C:\WINDOWS\SYSTEM\Rnaapp.exe 4.0 Microsoft(R) Windows(R)
Operating System
Tapisrv.exe 4.10.2222 Microsoft Corporation Microsoft® Windows(TM)
Telephony Server C:\WINDOWS\SYSTEM\Tapisrv.exe 4.0 Microsoft(R)
Windows(R) Operating System
What about this one...?...
Ddhelp.exe 4.09.00.0900 Microsoft Corporation Microsoft DirectX Helper
C:\WINDOWS\SYSTEM\Ddhelp.exe 4.0 Microsoft® DirectX for Windows®
PCR
pcrrcp@netzero.net
"LAH" <someone@somewhere.net> wrote in message
news:uQCWIHeKFHA.572@tk2msftngp13.phx.gbl...
the
data
to
from
it
specific
| > <snip>
| > Gary S. Terhune
| > MS MVP Shell/User
perhaps
have
| Windows 98SE
| HP Pavilion 8380
| 400 MHz Pentium II
| 224.OMB RAM
| 40 GB
> > <snip>
> > Gary S. Terhune
> > MS MVP Shell/User
have
> Windows 98SE
> HP Pavilion 8380
> 400 MHz Pentium II
> 224.OMB RAM
> 40 GB
Here's another data point.
I reported earlier that I had downloaded KB891711 last week and had
experienced no problems. However, tonight when I attempted my weekly
scandisk/defrag using GEODisk2, I got a BSOD. After a bit of
experimentation, I found that if I did a ctrl-alt-del and closed KB891711,
then invoked GEODisk2, scandisk/defrag would proceed normally. So far
that's the only anomaly I've encountered.
Win98SE
P11, 300MHz
320 meg RAM
"bobster" <fauxie@bogus.net> wrote in message
news
AOr8GgKFHA.244@TK2MSFTNGP12.phx.gbl...
from
specific
> > > <snip>
> > > Gary S. Terhune
> > > MS MVP Shell/User
perhaps
> have
> > Windows 98SE
> > HP Pavilion 8380
> > 400 MHz Pentium II
> > 224.OMB RAM
> > 40 GB
> Win98SE
> P11, 300MHz
> 320 meg RAM
And BTW, Comcast cable
...okay thanks Glen,
Rick
Rnaapp.exe 4.10.2222 Microsoft Corporation Dial-Up Networking Application
C:\Windows\System\Rnaapp.exe 4.0 Microsoft(R)Windows(R)Oper...
Tapisrv.exe 4.10.2222 Microsoft Corporation Microsoft Windows(TM)
Telephony Server C:\Windows\System\Tapisrv.exe 4.0
Microsoft(R_Windows(R)Oper...
Ddhelp.exe 4.09.00.09000 Microsoft Corporation Microsoft DirectX Helper
C:\Windows\System\Ddhelp.exe 4.0 Microsoft DirectX for Windows
Hope this is the information you requested. It seems identical to what you
posted.
Last night my 10 year old son did have some sort of error regarding Rnaapp.
I don't remember exactly what it was and don't know exactly what he was
doing when it happened. He was playing some sort of online game but had
left it for several minutes. I rebooted and all worked well after that. I
don't think it had anything to do with the problem you're discussing. More
likely it had something to do with a server timing out, difficulty
reconnecting to our ISP, or perhaps the temp files needed to be
emptied.<shrug> There weren't any more problems last night and things
appear to be OK this morning.
"PCR" <pcrrcp@netzero.net> wrote in message
news:%23vFRameKFHA.2136@TK2MSFTNGP14.phx.gbl...
> Have the problem.
> Can you...?...
> Operating System
> PCR
> pcrrcp@netzero.net
> the
> data
> to
> from
> it
> specific
> | > <snip>
> | > Gary S. Terhune
> | > MS MVP Shell/User
> perhaps
> have
> | Windows 98SE
> | HP Pavilion 8380
> | 400 MHz Pentium II
> | 224.OMB RAM
> | 40 GB
The latest suspicion implicates the video adapter / driver.
See other thread in this ng for details.
news:%23uMY9qcKFHA.2648@TK2MSFTNGP14.phx.gbl...
machines
> again.
> news
and
Celeron
for
<SNIP>
news:utwAsJgKFHA.1308@TK2MSFTNGP15.phx.gbl...
> news
the
data
to
> from
it
> specific
> > > > <snip>
> > > > Gary S. Terhune
> > > > MS MVP Shell/User
> perhaps
> > have
> > > Windows 98SE
> > > HP Pavilion 8380
> > > 400 MHz Pentium II
> > > 224.OMB RAM
> > > 40 GB
KB891711,
> > Win98SE
> > P11, 300MHz
> > 320 meg RAM
Another data point. At one time during my experimentation with the KB891711
problem, I uninstalled it using add/remove programs. This successfully
removed it from the start menu and MSCONFIG. When I later tried to
reinstall it from Windows Update I got the "no new critical updates
available" message. Since KB891711 apppeared to have little negative
effect, I had wanted to reinstall it to get the alleged protection it
provided. I did a "find files or folders" search and discovered that there
were two KB891711 folders remaining after the uninstall. Apparently Windows
Update erroneously saw these as evidence that KB891711 was resident on my
computer. I deleted them, went back to Windows Update and was able to
download KB891711 with no trouble. So far, the only problem I have seen
with KB891711 installed is the previously noted inability to scandisk/defrag
with GEODisk2.
I may contribute as follows:
DSL, but the problem which I'll describe seems independent from the Internet
conection.
> Registers, please.
A few hours (?) after installing KB891711, the computer (Win98 - Toshiba
portege 3110 CT) would show a black screen after logging in and a the moment
programs that shoud load at startup would try to do so. If I did not logged
in (leaving the login screen idle, i.e. not entering anything and NOT
clicking on "cancel" ), I could ping the computer and acces shared directories
frm another computer (through LAN). However, if I logged in, the computer
became inacessible at the moment its screen got black.
Starting the computer in safe mode, I systematically uncheked all programs
that I could see in the START tab using msconfig. I found that its was a
programme called CVPND. EXE (part of a CISCO VPN client version 4 that run as
a resident programme, waiting for the launch of the VPN client it-self ) that
caused the freezing of machine (unchecking this entry allowed me to log in
and have the machine to work normally) . However, I could no longer then use
my CISCO client ! Starting CVPND.EXE manually after completing a normal
booting, and then trying to run the CISCO client caused the screen to freeze
and to be splitted in 4 small miniature displays. All I could do at this
stage was to make a reset !
Unchecking KB891711 allowed me to re-enable CVPND.EXE and to run the CISCO
client and other programmes without problem.
I tried several tricks (like not logging in but simply clicking "cancel",
logging as another user than the usual one, etc...) but to no avail (the way
the screen froze differed [black screen, splitted screen, normal but frozen
screen, ... ], but the machine aventually always got stucked, unresponsive,
and inacessible from te network). The only way I could strat the computer
(and using msconfig) was in safe mode where averything seemed normal.
> anywhere, yet.
Unchecking Zone Alarm, Norton and CVPND entries allowed the machine to
start without problems with KB891711 running. All other programmes worked
fine.
> each juncture.
I did not test this but may do it if you consider it essential.
With an ME machine, I got a blue screen when trying to re-install Netscape
7.2 (which had been uninstalled because it had problems). The machine could
then be started in safe mode ONLY until KB891711 was unchecked with msconfig.
Now, my questions to you:
- at this point, what is best: leave KN891771 unchecked or unsinstall it ?
- when will Microsoft (a) remove this KB891771 from what can be donwloaded
and installed from Windows Update (b) have a corrected patch ready ?
- how safe is it to remain without KB891711 (but with a updated Zone Alarm
and Norton AV)
Paul.
> Gary S. Terhune
> MS MVP Shell/User
The machines here all have integrated Intel® 82810 Graphics Controllers.
news:eZdd3YjKFHA.3356@TK2MSFTNGP12.phx.gbl...
> machines
> > again.
> > news
> and
> Celeron
> for
> <SNIP>
"Paul (Bornival)" <PaulBornival@discussions.microsoft.com> wrote in
message news:771206F9-3F01-4F9E-805B-D400582178C1@microsoft.com...
Internet
> conection.
verbatim
> > Registers, please.
Toshiba
moment
logged
directories
computer
programs
was a
run as
it-self ) that
log in
then use
normal
freeze
this
CISCO
"cancel",
(the way
frozen
unresponsive,
computer
Startup
any
especially
> > anywhere, yet.
to
worked
> fine.
the
to
make
invasion.
and
Then
at
> > each juncture.
KB891711.EXE
Netscape
could
msconfig.
Thank you very much for these details. With any luck, a commonality will
be discovered sooner than later. No, I don't think you need to perform
any additional tests. My only intent is that we track down which
programs and procedures are affected. You seem to have detailed that
just fine.
it ?
If simply unchecking it in MSCONFIG solves the problem, then fine. If it
manages to reinstate itself, then you have no choice but to Uninstall
it. One thing you might try (not sure if you already have). Try
uninstalling it, then using Clean Boot procedures before reinstalling it
(see my sig for link to Clean Boot article.) Please, if you find any
change in behavior after reinstlaling in this manner, let us know, OK?
donwloaded
No word on either count. As silent as MS is being, I can only assume
they're working frantically to determine what's what.
Alarm
> and Norton AV)
Safe enough, *if* you exercise caution on the web, avoiding unknown
and/or risky sites. Also, if running Outlook Express 6, in Options, on
the Read tab, enable "Read in Plain Text Only". If not using a mail/news
client that can be set to "Plain Text Only", consider switching
mail/news clients. Also recommend SpywareBlaster and the MVPS HOSTS file
to prevent known malicious sites from resolving. See the second link in
my sig for further info.
The vulnerability is a real one, but it does require that you permit a
maliciously encoded HTML file to be rendered on your system.
Gary S. Terhune
MS MVP Shell/User
Jack,
My machine is 2 GHz, Celeron w/Asus P4SGX-MX MB w/SIS 650GX video chipset
currently in use.
The update patch caused IE to crash to BSOD, exactly like PCR's description.
Offline, IE worked great, loaded many .html's into it from off my local hd.
I'm on dial-up, simple DUN connection, no ISP s/w involved and do not use
ICW. Pc-cillin is my a/v s/w and my only firewall is via Pc-cillin, however
the puter is stealth per Gibson's site and my configuration of my firewall.
I have removed the patch KB891711. I have had no more problems, in fact, I
had no problems after I disabled it in msconfig, but I wouldn't expect to,
and I still have patch KB888113 which I took at the same time.
Personally, I won't use this update as it is configured to startup and run
w/Windows. I start any services I want to use after I connect to the
Internet... ONLY Pc-cillin starts up and runs w/Windows and I maintain a
normal startup.
What is Microsoft thinking... this patch is downright **Goofy** (my mild
opinion)!!
Star
> machines
> > again.
> > news
> and
timing
> Celeron
identical,
> for
> <SNIP>
To my knowledge, the KB891711 "patch" is adversely affecting some machines,
but not many. The common thread or cause is not yet apparent.
I don't know whether MS knew beforehand that this would occur.
I think that affected users should follow MVP Jim Eshelman's advice and
disable or uninstall the patch until further notice.
The patch does not execute in Safe Mode and can be uninstalled using the
Add-Remove Programs wizard, among other ways.
Your machine is one of the more new, more powerful ones to be affected, to
my knowledge.
Thank you for the report.
"Star" <star@yahoo.com> wrote in message
news:113i5ac23g8ldcf@corp.supernews.com...
> Jack,
> currently in use.
description.
hd.
however
firewall.
I
> normal startup.
> opinion)!!
> Star
those
> > > machines again.
> > > news
BIOS's and
out
timing
Celeron
identical,
reports for
> > <SNIP>
Glee, Star, Martinelli, all...
news
$AIqyzKFHA.580@TK2MSFTNGP15.phx.gbl
Subject: Re: KB891711
Date: Thu, 17 Mar 2005 17:01:54 -0500
It's long-winded, but there is a way I can get IE to work with KB891711.exe running. Hmmm, I'm starting to wonder, though, what it means...
Can it be, the instance of IE that is working that way is NOT protected by KB891711.exe?
PCR
pcrrcp@netzero.net
"Jack E Martinelli" <jemartin_DELETE@NO_SPAM_gis.net> wrote in message news:%23H6nZ3vKFHA.3616@TK2MSFTNGP09.phx.gbl...
| my knowledge.
| > Jack,
| > currently in use.
| description.
| hd.
| however
| firewall.
| I
| > normal startup.
| > opinion)!!
| > Star
| those
| > > > machines again.
| > > > news
| BIOS's and
| out
| timing
| Celeron
| identical,
| reports for
| > > <SNIP>
PCR,
You may be on to *something*, BUT that would depend on what you did to make
it work and you didn't share that finding!!
You are saying, **my IE crashes w/patch, and **IT SHOULD** as that is the
protection of the patch correctly working**
Yes/No, am I correct ??
Star
news
g31ZP0KFHA.1156@TK2MSFTNGP09.phx.gbl...
news
KB891711.exe?
PCR
pcrrcp@netzero.net
machines,
| my knowledge.
| > Jack,
chipset
| > currently in use.
| description.
| hd.
use
| however
| firewall.
fact,
| I
to,
run
| > normal startup.
| > opinion)!!
| > Star
| those
| > > > machines again.
message
| > > > news
| BIOS's and
| out
| timing
| Celeron
| identical,
| reports for
| > > <SNIP>
****Sooo, the patch prevents IE from launching... if the patch fails in
protection...****
Microsoft wouldn't make/design a patch like that PCR.
Star
news
news
KB891711.exe?
PCR
pcrrcp@netzero.net
machines,
| my knowledge.
| > Jack,
chipset
| > currently in use.
| description.
| hd.
use
| however
| firewall.
fact,
| I
to,
run
| > normal startup.
| > opinion)!!
| > Star
| those
| > > > machines again.
message
| > > > news
| BIOS's and
| out
| timing
| Celeron
| identical,
| reports for
| > > <SNIP>
I guess my write-up is confusedly written-up. Please go to that thread, though, & respond to it there. No, I said...
If an instance of IE is open offline, IE will continue to work after going online, UNTIL that instance is closed. Then, the BSOD resume at every attempt to open another IE or click an URL.
This is true, despite NetZero still caused a BSOD after it connected while trying to open it's home page.
But please go there.
PCR
pcrrcp@netzero.net
"Star" <star@yahoo.com> wrote in message news:113k5eb67luv672@corp.supernews.com...
| protection...****
| Star
| news
| news
| KB891711.exe?
....snip
Oh! It's unfortunate, but an Export of a Registry key will often look different from how it looks in the Registry.
(a) (default) shows up as @.
(b) Single slashes (\) become double (\\).
(c) What you said.
(d) Other even weirder effects.
PCR
pcrrcp@netzero.net
"bobster" <fauxie@bogus.net> wrote in message news:eKcntV1KFHA.576@TK2MSFTNGP15.phx.gbl...
| PCR, I now have KB891711 installed and it does appear as you said except the
| "IsInstalled" dword is slightly different, being, 0x00000001 [1]. Would be
| interesting to uninstall again and see if the circumstances are as before.
| That being said, I'm through foolin' around with the KB891711 issue as this
| particular anomalous behavior seems to have no bearing on the problem or its
| solution.
| news
EJLVU0KFHA.4092@TK2MSFTNGP10.phx.gbl...
| LAH, thanks, I no longer suspect those files.
| bobster, that's an odd circumstance you describe. I would think it's this
| Registry key that determines what the site thinks about it...
| "Locale"="EN"
| PCR
| pcrrcp@netzero.net
| news:eO6lAIvKFHA.2640@TK2MSFTNGP09.phx.gbl...
....snip
More of his "humor", I suspect. And you *still* listen to PCR?
Gary S. Terhune
MS MVP Shell/User
the
in
> protection...****
> Star
> news
> news
KB891711.exe
protected by
> KB891711.exe?
> PCR
> pcrrcp@netzero.net
> machines,
and
the
affected, to
> | my knowledge.
> | > Jack,
> chipset
> | > currently in use.
> | description.
local
> | hd.
not
> use
Pc-cillin,
> | however
> | firewall.
in
> fact,
> | I
expect
> to,
and
> run
the
maintain a
> | > normal startup.
(my mild
> | > opinion)!!
> | > Star
message
get on
> | those
> | > > > machines again.
> message
> | > > > news
same
> | BIOS's and
rules
> | out
BIOS
> | timing
and new
> | Celeron
indeed
> | identical,
Everest
> | reports for
DTS
> | > > <SNIP>
It's true I need to work on that, BUT this wasn't an example of it!
PCR
pcrrcp@netzero.net
news:u9yD002KFHA.3340@TK2MSFTNGP14.phx.gbl...
| Gary S. Terhune
| MS MVP Shell/User
is
| the
| in
| > protection...****
| > Star
| > news
....snip
That's interesting, because GEODisk was specifically designed to close ALL running
apps except Explorer. I wonder why it cannot close KB891711.exe, when it *can* be
closed manually using Ctrl+Alt+Delete. Hmmm....
news
2uxTvlKFHA.132@TK2MSFTNGP10.phx.gbl...
> > news
> the
> data
> to
> > from
> it
> > specific
> > > > > <snip>
> > > > > Gary S. Terhune
> > > > > MS MVP Shell/User
> > perhaps
> > > have
> > > > Windows 98SE
> > > > HP Pavilion 8380
> > > > 400 MHz Pentium II
> > > > 224.OMB RAM
> > > > 40 GB
> KB891711,
> > > Win98SE
> > > P11, 300MHz
> > > 320 meg RAM
> with GEODisk2.
Among the info I would like to see from posters having problems with update
KB891711(particularly blue secreens and freezes), is whether or not they are using
animated cursors/mouse-pointers in Windows, either as part of a Desktop Theme
(Control Panel> Desktop Themes) or simply as a mouse pointer option in Control
Panel> Mouse.
> Registers, please.
> anywhere, yet.
> each juncture.
> Gary S. Terhune
> MS MVP Shell/User
Glen,
On 98SE/IE6 fully updated and even running, "cough cough", NIS 2005 (actually
not so much as a hiccup). It has an animated pointer assigned by myself along
with the America at War theme.
Brian A.
Conflicts start where information lacks.
http://www.dts-l.org/goodpost.htm
news
VaQ99OLFHA.3512@TK2MSFTNGP15.phx.gbl...
> using
> Panel> Mouse.
>> Registers, please.
>> anywhere, yet.
>> each juncture.
>> Gary S. Terhune
>> MS MVP Shell/User
There are 2174 identified and unidentified users. To see the list of identified users, Click here.
By wombat_tg, 4 days ago:
You will need a dial-up account with an ISP in order to make use to that modem. (You're...
saran008 - bronze Expert
Specialties : Win 7, Win 9x, Win XP, Win Vista, Applications, Win 2000, Audio Tech
2205 messages since 1970/01/01
