Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Clicking on 'help' in the start menu.
In the 'troubleshooting' section, when I click on a choice in the right
frame the next screen which is supposed to give me a suggestion - that
screen is BLANK.
How can I reinstall the 'help' part of w98se to make *help* troubleshooting
work?
Sponsored Links
"Anon" <a_none_mous_e@hotmail.com> wrote in message
news:uwKdvHMKFHA.1396@TK2MSFTNGP10.phx.gbl...
> screen is BLANK.
> troubleshooting
> work?
Take a look here for a fix
http://mvps.org/PracticallyNerded/ [...] shootr.htm
if it says "Tshoot98.chm is missing". Better use...
http://support.microsoft.com/support/windows/tshoot
Windows Help Troubleshooters
Reply to HAGGIS
- 0 +
See inline comments
"Haggis" <bingsnapREMOVE@THIShotmail.com> wrote in message
news:%23osucTMKFHA.2716@TK2MSFTNGP15.phx.gbl...
> > screen is BLANK.
> > troubleshooting
> > work?
The problem is as described in the link above.
The problem DID occur after I installed two updates (not the one for ie6).
I installed tshoot.inf as instructed but the problem still persists.
I looked at this page also but none of the 'problems' listed fit the
'missing page' problem. When I clicked on 'network problems' (since this was
the problem I originally wanted cured, that link led to a "that page is no
longer available" error [meaning that MS has removed that page from their
KB.]
(There was no error message, just a blank page.)
Reply to ANON
The second update killed it by placing a killbit on the ocx. Simply
reinstalling tshoot.inf will not bring it back while the second update is
still installed.
See here for more detailed info and the workaround that removes the killbit
so you may use the Help Wizard and replaces the killbit when you close.
http://home.comcast.net/~bascon58/98_help.htm
Brian A.
Conflicts start where information lacks.
http://www.dts-l.org/goodpost.htm
news:ecZ8SXOKFHA.3640@TK2MSFTNGP12.phx.gbl...
> See inline comments
>> > screen is BLANK.
>> > troubleshooting
>> > work?
> was
> KB.]
Reply to Anonymous
- 0 +
"Brian A." <gonefish'n@afarawaylake> wrote in message
news:OBENjcPKFHA.484@TK2MSFTNGP15.phx.gbl...
> still installed.
killbit
All of the suggestions on the link state that they should NOT be used (which
I agree with in my case.) The 'download' patch which removes and replaces
the killbit when help is used sounds like a sure fire *problem* waiting to
really f***k up the system.
The only 'programs' listed in the add/remove part of the control panel are
microsoft VGX933989, Windows 98 KB891711 Update, w 98 Q823559 ud, Q840315,
Q888113, Q890175 (all with Windows 98 ---- Update.)
Which of these should I 'remove'?
Exactly what does the killbit do? I 'religiously do not open spam, and am
careful *which* url's I go to (but unfortunately - some are not what is
'advertised.)
I am not sure that I want to make the registry change as it is not explicit
enough as to what it DOES and what else will fail to work in the OS.
With knowing what the killbit does, maybe I can kill the killbit and get my
help screen back. Maybe with THAT informaion, I can proceed with more
assurance.The help is more important than some other things.
> Brian A.
> > See inline comments
right
that
> >> > screen is BLANK.
> >> > troubleshooting
> >> > work?
ie6).
> > was
no
their
> > KB.]
Reply to ANON
news:OfM4paRKFHA.3356@TK2MSFTNGP12.phx.gbl...
> (which
Not true, the workaround app (not a patch) works quite well without any
problems. All it does when you run it is remove the value for the killbit
set in the registry for tshoot.ocx allowing the wizards to work, when your
finished it places the killbit back.
None. Either running the install on tshoot.inf removed it from add/remove
or another update did. The killbit is still set in the registry and if
permanently removed opens the machine up to the vulnerability it was
implemented to close.
> 'advertised.)
Information on the critical update (Q824145)
http://www.microsoft.com/technet/s [...] 3-048.mspx
> explicit
> my
The small app suggested will do just that. If you choose to use it you may
need to run install on tshoot.inf if it fails to function at first, doing so
will allow full use of the wizards thru the app. The balls in your court
now.
Brian A.
Reply to Anonymous
Every cumulative IE critical Windows Update will take your
Troubleshooters away, for security reasons.
http://support.microsoft.com/defau [...] us;Q188867
Troubleshooting Windows 98 Startup Problems. This article contains a
link to what it says is the equivalent of the Windows Help
Troubleshooters...
That's it.
But, here is how to get them back when offline...
NOTE: This first step undoes a security measure put into one/two files
that will not get reinstated by the .reg's that follow. The .reg's only
disable/enable the kill bit.
First, "START, Find, F&F, Tshoot.inf"; R-Clk it & select "Install". You
still won't have the Troubleshooters. So, second...
(1) "START, Run, RegEdit"
(2) Navigate to
HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\ActiveX
Compatibility\{4B106874-DD36-11D0-8B44-00A024DD9EFF}
Compatibility Flags 0x00000400 (1024) <<Dword value 400
by
(a) Clicking plus signs, beginning with "HKEY_LOCAL_MACHINE",
(b) & ending with "ActiveX Compatibility".
(c) Finally, click "{4B106874-DD36-11D0-8B44-00A024DD9EFF}" itself in
the left pane.
(d) Now, you see "Compatibility Flags 0x00000400 (1024)" in the right
pane.
(e) "Registry menu, Export Registry file".
This will create a ".reg" file of the entire Key that is open...
all the items in the right pane & all sub-keys in the left pane (if
there is a plus sign). Give it a name & location of your choosing, even
to the Desktop or My Documents. Then, to undo the following, you will be
able to simply click that file, to Merge it's contents back into the
Registry.
Actually-- name that one "NoTrouble.reg". It will look like...
....Start.....
REGEDIT4
[HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\ActiveX
Compatibility\{4B106874-DD36-11D0-8B44-00A024DD9EFF}]
"Compatibility Flags"=dword:00000400
....End.......
(f) Close RegEdit. You now have an "undo" .reg, named "NoTrouble.reg".
(g) Make a copy of it called "Trouble.reg".
(h) Open "Trouble.reg" in Notepad. Change the "dword" to look as
follows... all zeros...
....Start..of "Trouble.reg"...
REGEDIT4
"Compatibility Flags"=dword:00000000
....End.......
CAREFUL: That "HKEY" is one line, with TWO spaces only. One between
"Internet Explorer", & the other between "ActiveX Compatibility". Make
sure it looks that way in Notepad, before you click to Save. Also, you
must have an empty line at bottom.
Now, "Trouble.reg" gives you the Troubleshooters. "NoTrouble.reg" will
give you security by taking them away. Remember to undo it, after you
are done looking at the Troubleshooters.
(2) By default, when a ".reg" is clicked, it will Merge into the
Registry. To alter the default behavior: "START, Settings, Folder
Options, File Types tab". Scroll to & click "Registration Entries",
click the "Edit" button, select "edit" in the window & click the "Set
Default" button. Now, when you click a ".reg" file, it will open in
Notepad for examination. To merge it into the Registry, R-Clk it &
select "Merge".
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
right
| screen is BLANK.
troubleshooting
| work?
Reply to Anonymous
- 0 +
see inline comments.
"PCR" <pcrrcp@netzero.net> wrote in message
news:OLIhqNTKFHA.2736@TK2MSFTNGP09.phx.gbl...
> Troubleshooters...
> That's it.
Problem - when I clicked on the networking link - the next screen said that
MS had removed that page.
Quick read looks like I have to import the notrouble/trouble files before
and after I want to use help - sounds like a non permanent fix????
<clipped rest>
Reply to ANON
- 0 +
See inline comment.
news:O4rN%23HSKFHA.4032@TK2MSFTNGP14.phx.gbl...
> > (which
replaces
to
are
Q840315,
am
> > 'advertised.)
Thanks - very detailed.
I guess I better leave the MS patch in - too many chances to screw up.
> > explicit
> > my
so
> now.
Got the ball.
I guess I will try the app, your assurance was what I needed. Thanks also
for the admonition about the tshoot.inf reinstall.
> Brian A.
Reply to ANON
news:OZnKOsXKFHA.2648@TK2MSFTNGP14.phx.gbl...
| > Troubleshooters...
| > That's it.
that
It works for me. It resolves to...
http://support.microsoft.com/defau [...] efault.asp
....& the Troubleshooters are there!
before
The do guy is permanent, until you click the undo guy, which is
recommended. Isn't much to do, but it applies only to the "kill bit".
In step one, WHATEVER the Tshoot.inf reinstalls (with it's
vulnerability) is never undone, until you take the next critical IE
update. I really don't know whether the kill bit is sufficient. It
certainly does kill those Help screens, though.
files
only
You
| <clipped rest>
PCR
pcrrcp@netzero.net
Reply to Anonymous
- 0 +
news:OxBMW4aKFHA.1528@TK2MSFTNGP09.phx.gbl...
> | > Troubleshooters...
> | > That's it.
> that
Your link is a page with the LIST of troubleshooting pages.
Clicking on "I need help with networking" gives a page with the following
message at the top:
"The Requested Web Page is Not Available"
> before
> files
> only
> You
> | <clipped rest>
> PCR
> pcrrcp@netzero.net
Reply to ANON
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > problem with "help system"
There are 992 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
