Hi i just assembled a new rig but am facing some problems running the thing.
My Specs: (Running at Bare minimum)
Seagate 300Gb SATA 2 hard disk
AMD Fx-55 Clawhammer
MSI K8N Diamond Plus
Inno 3D Geforce 7900GT
512 PC3200 DDR400 Kingston RAM
No OC or anything. Everything running on stock coolers
When i boot up i get the following error:
CMOS CheckSum BAD
Press F1 to try and repair (This takes me to the BIOS)
Press F2 to load default values and try starting (THis resets BIOS defaults)
F1 has no use cos when it restarts it goes back to the same screen
On F2 i can go into the Windows Xp loading screen but then the comp shuts down. On restarting and going thru F2 again it shows the "windows didn't start properly" screen. Here i am able to run all safe mode boot options but not normal windows. I can go in using safe mode and surf net and everything but normal windows won't load.
So any suggestions on this? I suspect it's the mobo.
CMOS CheckSum BAD
