Tempurature PLEASE READ! MBM5 WRONG?
I have my 3700+ Oc'd and temp in MBM shows high temp of 47C right now at idle it is 36C.. I read a couple posts on other chips. wondering if these temps ok with the 3700. Thanks.
Edit: While doing Prime 95 Heat test, MBM shows my CPU staying at 36C while it shows case temp at 46 Could they be switched around?
Edit2: after running several times to same result, i figure they are switched. anyone know why or how this happend?
2 answers Last reply
More about tempurature read mbm5 wrong
  1. ASRock dual series 939.. figures..
    what else should i use thats the same thing
  2. thanks
AMD Overclocking
