Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Help?! Lost Win 98 Product key card
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Hi all,
I had to dump my corrupted OS, only to find that I lost the product key
certificate, and that this laptop predates when they started installing
stickers or etching on the terminal itself. Can anyone direct me to the part
of the site where I can look it up? I registered it at the time. Cheers!
Sponsored Links
zimich <zimich@discussions.microsoft.com> wrote:
>Hi all,
If you have reformatted the hard drive and cannot find the Certificate
of Authenticity then you are pretty much out of luck.
Your best bet might be to try one of the "unformatting" utilities and
hope that it can recover enough of the hard drive so you can locate a
registry backup, which would be an RBnnn.CAB file from the
\Windows\Sysbackup folder.
The product key could then be located within the backed up registry
files.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Reply to Anonymous
There are 574 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
