Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > NDIS error on <900mhz machine? HELP!
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - NDIS error on <900mhz machine? HELP!
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Help! I was installing a new mouse on my parents computer 900mhz AMD, old
ps/2 mouse for a new Labtech Optical USB mouse. Everyting went fine until I
rebooted and then I got the error message 'Windows Protection Error'. I then
rebooted and I got the next error 'While initializing device NDIS: Windows
Protection Error'. I was able to boot into safe mode and do some searching
about. I find a fix for a faster computers but nothing for me. Sometimes if
I do a logged boot I can start windows normally. (like now) The boot log
states that the ndis2sup.vxd failed to load. A couple of times when I've
rebooted I get the following error 'While initializing device IOS, an I/O
subsys subdirectory is corrupt or the system is low on memory'. Everything
was working fine on the computer until then, if anyone can help me with this
I would be most thankful.
Good Luck,
Sponsored Links
Does removing the new mouse resolve the problem? If not I'd be looking at
other hardware problems, most likely either bad memory modules (RAM), a
failing power supply, or faulty cooling fans inside the unit.
Richard G. Harper [MVP Shell/User] rgharper@gmail.com
* In fond memory ... Alex, you shall be sorely missed
* http://www.aumha.org/alex.htm
"WinterRaven" <WinterRaven@discussions.microsoft.com> wrote in message
news:8EB8EF67-67D3-4A06-93F0-AF30B40964B4@microsoft.com...
> I
> then
> searching
> if
> Everything
> this
> Good Luck,
Reply to Anonymous
Why would I be getting the NDIS come up? (but not all the time). Doesn't it
look like there is some sort of conflict somewhere? I've removed the USB
mouse and there doesn't seem to be a change. Power supply and fans check out
fine. Could Ram fail just from an install? I wish there was a diagnostic
that came with windows to help solve these issues. I just want to leave this
weekend with my parents computer in a usable state. Should I just reinstall
Win98 and if so what is the best way? (without losing bookmarks, email etc.)
Thanks
> > I
> > then
> > searching
> > if
> > Everything
> > this
> > Good Luck,
Reply to Anonymous
Anything can fail at any time. Coincidences do happen. If it's a hardware
problem reinstalling Windows will likely fix nothing and probably leave you
in a worse mess if the system crashes during the process.
"Winter Raven" <Winter Raven@discussions.microsoft.com> wrote in message
news:14426F74-8ED9-4C1D-A795-6230D6A8386F@microsoft.com...
> it
> out
> this
> reinstall
> etc.)
> Thanks
>> at
>> > old
>> > until
>> > I
>> > I
>> > then
>> > Windows
>> > searching
>> > Sometimes
>> > if
>> > log
>> > I've
>> > I/O
>> > Everything
>> > this
>> > Good Luck,
Reply to Anonymous
There are 534 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
