Archived from groups: microsoft.public.win98.gen_discussion (
More info?)
Wryly Post <act1seen2hsd@earthlink.net> wrote:
>serial.vxd, vmm32.vxd, serialui.dll.
If vmm32.vxd has actually been removed from your computer and you do
not have a recent backup copy of it then you *must* reinstall Windows.
Vmm32.vxd is a composite file that is custom built during the Windows
install process. The content of the file is determined by the actual
hardware components contained in the computer. There is a vmm32.vxd
file contained in the .cab files on the Windows 98 installation CD but
that is just a "stub" file that is used as the starting point for
building the actual file.
But check and doublecheck for the existence of vmm32.vxd on your hard
drive before you reinstall Windows. There are circumstances where
false errors about this file being missing can be produced.
To check for the existence of the file boot the computer to "command
prompt only" or with a Windows 98 Startup Boot Disk and enter the
following command:
DIR C:\VMM32.VXD /A /S
If the result is "file not found" and you don't have a backup on
another disk somewhere then the only option is to reinstall.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
