Archived from groups: microsoft.public.win98.gen_discussion (
More info?)
It looks like dadiOH came up with an alternative place to get
ContextEdit, as well as an alternative app. I tend to agree with him
about the complexities involved, but Richards has an URL that may afford
an explanation of it. Maybe Richards is different, but before I engage
into intensive study to solve your duplicate QuikView, I'll want to know
the apps didn't easily solve it first.
Do you see two of them at...?...
"START, Settings, Folder Options, File Types tab"
....is likely the first thing Richards will want to know.
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
"Anon" <a_none_mous_e@hotmail.com> wrote in message
news:eaFEgyJPFHA.1096@tk2msftngp13.phx.gbl...
| See inline questions
| "PCR" <pcrrcp@netzero.net> wrote in message
| news:eL9SnvHPFHA.3392@TK2MSFTNGP10.phx.gbl...
| > "ContextEdit", Version 1.2, in it's own words:
| > ...........Start.............
| > DESCRIPTION:
| > ContextEdit lets you control which items appear on your context
| > menu--the menu that appears when you right-click on an item in
Windows
| > Explorer. The context menu often contains numerous rarely-used
commands.
| > These commands come from one of two places: shell commands stored
within
| > the system Registry,
| Where in the registry - and what do the "commands" look like?
| and context menu handlers.
| Where are these located - and what do the "commands" look like?
| The source of the menu
| > item is transparent to the end-user, but still has an impact.
Windows
| > Explorer lets you add or remove simple shell commands, but gives you
no
| > control over context menu handlers.
| Does this mean that I cannot change any of these???
| ContextEdit lets you control both
| > types of context menu items. It also allows you to disable context
menu
| > items without removing them entirely.
| How and where do I do this?
| Another unique feature is the
| > ability to add shell commands
| I have hear of "shell commands" before, but again how do *I* make any
| changes in the shell commands (and where are the changes made?)
| to all files regardless of type, or to all
| > files without an associated program.
| > ..........End...............
| > http://www.pcmag.com/ Has many, many great utilities: BHOCop, COA2,
| > ContextEdit, Crackup, DiskAction, EndItAll2, Folders, HDValet,
InCtrl5,
| > ListZapper, RegDetective, RegEdit+, StartupCop, WinTidy, etc. Now,
| > suddenly, there is a subscription fee at PCMag, but, it's worth it,
| > especially if you can get the whole bundle that is there.
| > .........Start..................
| > Yearly billing $19.97
| > Yearly billing (For PC Magazine subscribers) $14.97
| > Monthly billing (limit 3 downloads/month) $4.97
| > .........End...................
| > You may try Google, but do you really want to download from any odd
| > site?
| > http://www.google.com/
| > PCR
| > pcrrcp@netzero.net
| > news:u4QwjrGPFHA.1172@TK2MSFTNGP12.phx.gbl...
| > | When I right click on a file icon, I get a pull down menu with a
lot
| > of
| > | choices - where is the "folder" that contains all of the choices -
| > there is
| > | one I wish to remove.
| > | The choices are quick view, open with, open, quick view, etc.
(this is
| > not
| > | the sendto folder.) Note that quick view is in there TWICE and I
want
| > to
| > | remove one of them.
