start up problem
Last response: in Windows 95/98/ME
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I installed some new software and now get the following message at startup.
The RUNDLL32.EXE file is linked to missing export KERNEL32.DLL:ActivateActCtx.
I can get past that but cannot access some things like the Control Panel,
Windows updates, etc. Can anyone tell me how to fix this.
More about : start problem
The error means that rundll32.exe is expecting a function of kernel32.dll that is
not supported by that version, namely the function ActivateActCtx. This function is
not supported by the Win98/98SE version of kernel32.dll. This suggests that you
installed some software that does not work on Win98/98SE, as the function is
supported by the kernel32.dll in Windows XP.
I suggest you uninstall the program that instigated the error, reboot, and if the
error still persists, extract a new copy of rundll32.exe from your Windows CD (or
the .cab file location on your hard drive) to the C:\Windows folder, using the
"Extract one file" option of System File Checker (SFC).
Using SFC to extract a file:
http://www.rickrogers.org/sfc.htm#1pp
http://www.rickrogers.org/sfc.htm#2pp
HOW TO: Extract Original Compressed Windows Files:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;129605#5
http://service4.symantec.com/SUPPORT/tsgeninfo.nsf/doci...
or
http://tinyurl.com/3pyth
Glen Ventura, MS MVP Shell/User, A+
http://dts-l.org/goodpost.htm
http://www.microsoft.com/communities/conduct/default.ms...
"Pete M" <Pete M@discussions.microsoft.com> wrote in message
news:D 6CA952F-C8EC-4215-8BC6-3C3AA4C2604A@microsoft.com...
(A) Extract a new RUNDLL32.EXE, if "access denied" is mentioned...
RUNDLL32.EXE
Desc: Run a DLL as an App
Loc: C:\WINDOWS
Mod: Friday, April 23, 1999 10:22:00 PM
Ver: 4.10.1998
That is old enough (Win98SE) never to have been modified by an update.
So, extract it with SFC.
(1) "START, Run, SFC"
(2) Bolt "Extract one file from installation disk"
(3) Enter "RUNDLL32.EXE" in the "Specify..." box.
(4) Click "Start". It should offer to "Save file in C:\WINDOWS".
If not, make it so.
(5) In "Restore from", if not already pre-filled, browse to
(a) Installation CD (likely the Win98 folder) or
(b) The folder that has your cabs on the hard drive, likely
"C:\WINDOWS\options\cabs\".
(5) Click "OK"
If it discovers the file already exists, it will offer to back it up.
May as well do so. If it discovers the file is "in use", it will request
that you reboot to complete the install.
(B)
http://search.support.microsoft.com/kb/c.asp?fr=0&SD=GN...
Search: "Control Panel"; Title only; Exact match; finds many,
including...
http://support.microsoft.com/default.aspx?scid=kb;en-us;299923&Product=w98
How to Troubleshoot Control Panel Issues in Windows
(299923) - When you attempt to open Control Panel (click Start , point
to Settings , and then click Control Panel ), it does not open as you
expect. One or more of the following may occur: You receive an error
message similar to the following: Program has...
http://support.microsoft.com/default.aspx?scid=kb;en-us;192806
How to Run Control Panel Tools by Typing a Command
(192806) - This article describes how to run Control Panel tools in
Windows by typing a command at a command prompt or in the Open box.
http://support.microsoft.com/default.aspx?scid=kb;en-us;149648&Product=w98
Description of Control Panel (.cpl) Files
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
startup.
Panel,
Ask the community
