When I try to start the system, nothing happens, nothing on the screen, no beeps nothing (all the component do start whirring though and yes I have pluged in the pci-e cable)
On the 1900XT card both the ext_pwr and t_fatal leds are lit...
I'm guessing the card is simply a duff card but I thought i'd check...
AMD Athlon 64 3400+
ATI Radeon 1900XT PCI-E
Gigabyte GA-K8NE
3GB DDR 400 (have tried with these in every combination and with only 1 or 2 of the sticks in)
Creative X-FI Xtreme Music
580W PSU (does supply the required 30A)
This is my first PCI-E build and unfortunetly dont have another pci-e mobo or vga to try
Only thing I know is those 2 lit leds dunno if its the vga or mobo, just hoping the fact those 2 leds are lit will help diagnose the problem.
Any help will be apreciated..
AMD Athlon 64 3400+
Gigabyte GA-K8NE
