Archived from groups: microsoft.public.win98.gen_discussion (More info?)
Hopefully someone can provide a quick solution:
I upgraded a machine from Windows 95 to Windows 98SE. Now, I can't connect
to anything on the LAN. I can't ping anything either. I get a time out
everytime.
Everything network wise is setup properly. Cabling is fine also. I was
able to work on the LAN with another computer connected to the same line.
I also removed the network card and re-added. I tried a new network card,
and still nothing.
It seems it's something in Windows that is doing the blocking. Any ideas?
Sponsored Links
I would more assume that the Networking software and configuration
didn't survive the upgrade, whether it "looks right" or not. My usual
response is to wipe out everything in the Network applet in Control
Panel, then remove the network card in Device Manager (again), then
restart and reinstall everything from scratch.
Actually, rather than restart normally, I'd restart directly into Safe
Mode and check Device Manager there for any "ghost" entries or
duplicates. Not just in the Network adapter section, but in the entire
DM. While it's expected that some entries get duplicated (IRQ Holders,
some System devices and USB devices) if there is more than one entry for
a physical device, you have problems. Post back here with the list of
any duplicated devices--name and how many.
Gary S. Terhune
MS MVP Shell/User
http://www.grystmill.com/articles/cleanboot.htm
http://www.grystmill.com/articles/security.htm
"Muskett" <rg@yahoo.com> wrote in message
news:%23zcbuzGRFHA.3708@TK2MSFTNGP15.phx.gbl...
connect
out
> everytime.
was
line.
card,
> and still nothing.
ideas?
Reply to Anonymous
Thanks so much for your response. I did try to remove everything in Network
Neighborhood. But, when I click on OK to exit the hour glass never goes
away. It just hangs. If I remove only one component, like TCP/IP, it's ok.
But, if I remove all, the computer hangs. Would I be able to remove them in
Safe Mode?
Thanks again.
"Gary S. Terhune" <grystnews@mvps.org> wrote in message
news:uRfVu6GRFHA.2960@TK2MSFTNGP15.phx.gbl...
> Gary S. Terhune
> MS MVP Shell/User
> connect
> out
> > everytime.
> was
> line.
> card,
> > and still nothing.
> ideas?
Reply to Anonymous
Not sure. Worth a try, though. Perhaps, also, physically removing the
NIC card and then cleaning up Network and Device Manager, would help. My
gut tells me that whatever the hang is due to is also the reason for the
problem in the first place.
Might also read my "Clean Boot" procedures (link in my sig) and stop all
background processes, since one or more may be attempting to establish a
connection. Anything that is trying to do something over the network and
failing is also probably responsible for the "can't remove" problem.
Gary S. Terhune
MS MVP Shell/User
news:OAx8BwHRFHA.3288@TK2MSFTNGP14.phx.gbl...
Network
goes
it's ok.
them in
> Safe Mode?
> Thanks again.
usual
Safe
entire
Holders,
for
of
> > Gary S. Terhune
> > MS MVP Shell/User
can't
> > connect
time
> > out
> > > everytime.
I
> > was
same
> > line.
network
> > card,
> > > and still nothing.
Any
> > ideas?
Reply to Anonymous
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Network problem
There are 539 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
