help again
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
I'm trying to install my Lexmark Z23 printer and when it gets to
installation, it says "Can't load LXSUPMON.DLL" then it says "Error copying
file- lexstart.ex_." what can I do?
11 answers Last reply
More about help again
  1. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    I assume you're using a Lexmark CD to do this? Go here to get the latest installation files.
    http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:285:0:0&os_group=Windows%2098
    (TinyURL = http://tinyurl.com/95ekg)
    Gary S. Terhune
    MS MVP Shell/User
    http://www.grystmill.com/articles/cleanboot.htm
    http://www.grystmill.com/articles/security.htm
    "al" <al@discussions.microsoft.com> wrote in message news:7921C977-25DB-43FC-9CEB-CB7B42675FEB@microsoft.com...
  2. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Shovin n pushin my way in front of Gary.
    Download the latest updated drivers as suggested by Gary and dl'd/copy/unzip
    the file/s in a folder of their own for now.
    Now head for Control Panel > Add/Remove Programs and uninstall anything related
    to the printer or other past printers.
    Once finished, if you do not know where apps/files were installed for the
    printer, use Find > Folders/Files to locate any left behind remnants that can be
    deleted. Many poorly written install/uninstall apps do not remove Start Menu
    sc's and or folder/files from where the app was installed.
    Next after a quick reboot empty the Temp, IE temp and cookie folders.
    Figure I need to mention this for others:
    Within the past 48hrs I have uninstalled Nero OEM Express6 along with the very
    few app,( that's right, no s at the end ) that came with it. After Add/Remove,
    cleaning installation drive and everything I could find on C: I ran a registry
    check on Ahead and Nero. It came up with more than 750 entries left in the
    registry, all legit Nero which I removed. I then installed the updated version
    of what was wanted to the wrong drive purposely monitoring it with Total
    Uninstall. After installing, rebooting and clearing out all temps, I restarted
    TU and ran the uninstall to remove the Ahead/Nero apps installed. After TU was
    finished I ran the registry scan again and it came up with approx 450 entries.
    We are talking about a major app that doesn't have a very good
    uninstall/cleanup.
    Brian A. Sesko
    { MS MVP_Shell/User }
    Conflicts start where information lacks.
    http://www.dts-l.org/goodpost.htm
  3. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    "Brian A." <gonefish'n@afarawaylake> wrote in message news:umZOhAHSFHA.204@TK2MSFTNGP15.phx.gbl...
    Hey, watchit, buddy!
    Oh... Nevermind, I can see by that hammer in your hand that you mean business, ;<)
    (Does anybody really use hammers anymore, or just a weel-stocked arsenal of nailguns?)
    Good catch!
    Beginning to sound like a Clean Boot procedure, <eg>.
    > uninstall/cleanup.
    Ewww! Yucky!
    Gary S. Terhune
    MS MVP Shell/User
  4. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    +"Gary S. Terhune" <grystnews@mvps.org> wrote in message
    news:uMWwPGHSFHA.2932@TK2MSFTNGP09.phx.gbl...
    NICE! Keep it both ways and hope no notices!
    nailguns?)
    Well, let's ponder that?
    I have used a 28oz "mini-persuader" since my mid 20's, and BION, I still have
    that hammer which has a FG handle. The Reason we all won't rid of them is
    because if we do, then we offset the balance. Offset the balance = Tilted walk =
    Put the man on a roof.
    > related
    Good catch!
    It was near the Doc. Only ~~~~~~~~~~~~~~ that far away.
    > be
    > very
    > uninstall/cleanup.
    Ewww! Yucky!
    100% !! What prompted me to into this pshycotic venture, was the machine in Q
    kept having assoc's yanked out from underneath by Nero. When I first noticed it
    took .dat files as it's own prize, I removed the assoc to only see that within a
    day or so it dug it's claws in and pulled it under.
    Gary S. Terhune
    MS MVP Shell/User
  5. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Seems like Nero's installer/uninstaller has long had this sort of problem. I recall
    sending their support people a "few" pages of such problems that I documented after
    doing a few installs and uninstalls of Nero 5.5 shortly after it came out. One that
    stands out in my memory was that the uninstaller would, instead of just removing the
    single "Nero Shell Extension Property Sheet" entry in the key:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Shell
    Extensions\Approved,
    the uninstaller would remove the entire key! They fixed that one in a later
    sub-version.
    IIRC they finally got v.5.5.x to behave decently when uninstalling....looks like
    they have to start all over with v.6.x!
    Glen Ventura, MS MVP Shell/User, A+
    http://dts-l.org/goodpost.htm
    http://www.microsoft.com/communities/conduct/default.mspx
    news:OZBUKOISFHA.1176@TK2MSFTNGP12.phx.gbl...
    > nailguns?)
    > > related
    > Good catch!
    > > be
    > > very
    > > uninstall/cleanup.
    > Ewww! Yucky!
    > Gary S. Terhune
    > MS MVP Shell/User
  6. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Brian A. Sesko
    > related to the printer or other past printers.
    > be deleted. Many poorly written install/uninstall apps do not remove Start
    > Menu sc's and or folder/files from where the app was installed.
    > uninstall/cleanup.
    > Brian A. Sesko
  7. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Gary S. Terhune
    MS MVP Shell/User
    news:O9fIZ8hSFHA.3516@TK2MSFTNGP10.phx.gbl...
    > Brian A. Sesko
  8. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    there are cleaning tools available on the nero site
    > Brian A. Sesko
    >> dl'd/copy/unzip the file/s in a folder of their own for now.
    >> can be deleted. Many poorly written install/uninstall apps do not remove
    >> Start Menu sc's and or folder/files from where the app was installed.
    >> very few app,( that's right, no s at the end ) that came with it. After
    >> Add/Remove, cleaning installation drive and everything I could find on C:
    >> I ran a registry check on Ahead and Nero. It came up with more than 750
    >> entries left in the registry, all legit Nero which I removed. I then
    >> installed the updated version of what was wanted to the wrong drive
    >> purposely monitoring it with Total Uninstall. After installing, rebooting
    >> and clearing out all temps, I restarted TU and ran the uninstall to
    >> remove the Ahead/Nero apps installed. After TU was finished I ran the
    >> registry scan again and it came up with approx 450 entries. We are
    >> uninstall/cleanup.
    >> Brian A. Sesko
    >>> copying
  9. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    Good ?, how did this get here? I'm sure it's something I did not noticing it.
    Brian A. Sesko
    news:u8JnbXiSFHA.2520@TK2MSFTNGP09.phx.gbl...
    > Gary S. Terhune
    > MS MVP Shell/User
    >> Brian A. Sesko
  10. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    I know. Don't need em, but if I ever do, I know. Thanks.
    Brian A. Sesko
    "Haggis" <bingsnapREMOVE@THIShotmail.com> wrote in message
    news:uvbT0ImSFHA.3188@TK2MSFTNGP09.phx.gbl...
  11. Archived from groups: microsoft.public.win98.gen_discussion (More info?)
    What?
    Thanks or Good Luck,
    There may be humor in this post, and,
    Naturally, you will not sue,
    should things get worse after this,
    PCR
    pcrrcp@netzero.net
    | Brian A. Sesko
Microsoft Windows
